High Desert of eastern NM
Postby Centerlane » Sun Apr 05, 2020 1:37 pm
So, I've tired of tenting and have decided to build a TD.
My hats of to those of you that build in small garages, or no garage at all.
I've been in construction most of my life, have a large shop, a lot of tools
and it should be a quick easy build :) So I thought :frightened:
If I can learn how to post pictures, I have a few.
EDIT: FIRST PICTURE WAS TAKEN 12-01-19
Centerlane
Images: 105
Re: High Desert of eastern NM
Postby kscmpr54 » Sun Apr 05, 2020 4:20 pm
Welcome to the forum. Looking forward to your pictures. Best wishes on your build.
kscmpr54
Postby pchast » Sun Apr 05, 2020 9:07 pm
Welcome. :D
pchast
Images: 97
Postby noseoil » Mon Apr 06, 2020 7:22 am
Where are you? We're in Raton...
Just go to your profile & start adding images, from your computer into a gallery. Once they're in your gallery, you can click on them individually, swipe across the link that opes (I use the center one) & copy it into your post thread. It's easy to use, you just can't upload directly to your thread from the computer, it's an extra step to set up the gallery. I usually open two versions of the TNTTT in the browser, so you can go back & forth between them when posting images. Hope this helps.
137905
noseoil
Images: 669
Postby Centerlane » Sat Apr 11, 2020 9:31 pm
Soo, one day when I discover how to add photos, I will. :thinking:
It is to be a Benroy type, the " box" 54" H X 57" W X 120" long.
I didn't want a wide track, it's already gona be 3" wider than most mid-size vehicles.
I wanted the height , because ,I want a real bed, if you call a fullsize mattress a real bed.
2-challenger doors :cry: they are lotsa$$$
Nose, I"m in Clovis ,the side no one comes to, but every one wants to leave..
The Whittington center is on the list, probably one of the safest places on earth, unless you've a big mouth.
Been there a number of times.
Maybe I'll learn up the pictures mannana.
Stay safe and stay in the shop :beer:
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:09 am
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:12 am
gallery/image.php?album_id=5081&image_id=161603
3/4" cdx
EDIT:THIS FIRST PICTURE WAS TAKEN 12-01-19
and I have tried to edit the url. to no avail.
I'm obviously not in IT. :(
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:15 am
161601
Big'ens out of little ones.
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:21 am
161607
press
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:33 am
161674
radi jig
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:37 am
161675
No pict. but i cut the inter panel, using a bearing bit, then a 3/16" straight bit using a fence, saving the2" strip to use later in-between the spars
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:39 am
161608
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:41 am
161609
Floor 3/4" poplar frame
1/8" bb bottom
1/4" bb top, inset 7/8" to create rabbet
3/4" eps center
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:47 am
[img][/161610]
Fully adhered TPO roofing material, with contact cement.
It did add 15#
Centerlane
Images: 105
Postby Centerlane » Mon Apr 13, 2020 11:51 am
[img][/161611]
Interior, no stain.
Centerlane
Images: 105
