Attaching camper body to trailer
Postby cluttonfred » Tue Apr 07, 2020 1:15 pm
I am planning a Wanderer 10 build from Andy G.'s simple plans. One question I have, as a complete TNTTT newbie, is pretty basic: "How is the camper body attached to the trailer?"
The Wanderer uses two 1 x 6 boards directly over the trailer cross beams as key structural members, but what is the best way to then attach the body without weakening the trailer? Here's a detail from the plans for clarity:
161543
Thanks and regards,
Matthew
Matthew Long, Editor
cluttonfred.info
A site for builders, owners and fans of Eric Clutton's FRED and other safe, simple, affordable homebuilt aircraft
« Voici ce que j'ai fait...vous pouvez en faire autant! » "This is what I have done...you can do the same!"
--Henri Mignet (1893-1965)
cluttonfred
Re: Attaching camper body to trailer
Postby cluttonfred » Thu Apr 09, 2020 12:11 pm
Anyone have any thoughts on this? I have yet to find anything like a build log of a completed Wanderer. Cheers, Matthew
cluttonfred.info
cluttonfred
Postby knova » Sun Apr 12, 2020 8:49 pm
There was a large discussion thread about this previously, there are different opinions on what kind of bolt to use. I choose to use 12 elevator bolts around the floor, countersunk in.
Personal website: https://www.novakeith.net
Family website: https://novaks.us
Listen to my music: https://music.knova.net
knova
Postby noseoil » Fri Apr 24, 2020 7:30 am
You can use one 1/2" bolt in the center, plenty of shear strength (grade 5 is 14,000#). Otherwise, use a few on each side, here's a link on single shear of common bolts.
https://www.nucor-fastener.com/Files/PD ... rength.pdf
137905
noseoil
Images: 669
