This past year I somewhat completed a project in which I placed a Solar Controller in my tongue box.
The real pain with this project was in trying to get wires to fit into the slotted openings of the solar controller. The problem was that my controller panel was tight to the floor of the tongue box yet the wires needed to be connected into the box essentially blind.
The more I struggled with this the more frayed the wires got, which meant less wire segments were clamped into place and also many brittle strands just broke off.
I may have gained a couple inches more of slack by disassembling the retainment of the wiring. I was getting very short specially the positive cable.
Here is a picture of the mess that I'm trying to fix.
I am considering relocation of the wires flush to the back of my tongue box. Presently I have a plywood piece separator. If I raise this up or tilt it perhaps I could get less of a blind reach to get inside the solar controller electrical feeds. The down side of raising this up is that I believe I'm supposed to have something like 6 inches of air circulation clearance above the unit.
Even though this is a problem of itself the main issue right now that I'm concerned with is how to deal with the frayed wires.
In my best case scenario I've considered I would cut off the frayed ends and possibly apply solder on the ends without getting larger than the slotted openings of the controller. Does this sound right? If not what are your ideas? I've never worked with solder but do have a Soldering gun.
