Hello, I would like to consult my plans for wiring my teardrop trailer as well as get any recommendations for materials and ideas.
Bear with me, this is my first attempt
Its a small 5x8 teardrop that will be running primarily 12V but I want to have a 120V available when connected to shore power (with an option to get inverter in the future)
There will be no large draw on the 120V AC system, no air-conditioning, largest item will be 300W ceramic heater and a laptop charger.
The 12V DC system will be running the interior / exterior lights as well as couple 10Amp 12V outlets.
The 12V DC portion is pretty straight-forward, I am setting the solar part with 10AWP and 30Amp breaker/switches ready to accept up to 300W solar in case I want to expand.
The battery will be grounded to the frame, but all wires will have a return wire as I dont want to use frame as return path.
Majority of my question is around the 120V AC side of the things and about recommendations for materials (which i will get to later).
1. Should i have any EMS / Surge protector on the shore power? I've read people are recommending those because campsites are usually very inconsistent, but I could find are made for 30Amp plugs (for larger RVs).
Should I get one for my small 15Amp circuit and are there any regular outlet 15Amp EMS ? .. I can always get a regular outlet surge protector probably.
2. I want to have breaker/switch on the 15Amp shore power input, which will be grouned to frame (to prevent hot skin). The second breaker will be the system that goes into the trailer, and will just regullary plug into an outlet inside tongue box.
This is just a simple solution so that I can add a inverter in the future and plug the rest of the system in it, while leaving the battery charger connected to the shore power only plug.
Also I want to have a GFCI breaker so that the whole circuit running to the back of the trailer is protected not just the end receptable.
Is the two breakers overkill for my small application?
Can you recommend any small housing / breaker panel for having 1 breaker only ? I Believe the smallest i could find are 60Amp (2 breaker) boxes.
I dont want to mix those two breakers inside a single panel as those two things can be disconected from each another.
Material:
Because the trailer is pre-build unfinished teardrop, I unfortunatelly can no longer run cables through the insulated floor/ceiling.
I am planning on running the cables from the tongue box to the rear galley of the teardrop (about 9ft one way) under the trailer.
I will run a 12V DC on one side of the trailer and 120V AC on the other so that the two circuits are not stack next to each other.
3. Can you recommend any good wire for running under the teardrop? I know there are THHN/XHHW or armored wires (
https://da.lowes.ca/webassets/images/22 ... 75_001.jpg) - however the armored ones usually have explicit statement about being for indoor/dry use only (which i dont understand
4. Can you recommend any protection for the wires while running under the trailer - is standart wire loom be enough? (
https://www.amazon.ca/Split-Tubing-Cond ... B07KDFD3WP)
5. Any other general ideas? or mistakes I made that immidiately strikes you?
Thanks for any help!
- Trailer Electrical (4).png (477.83 KiB) Viewed 1836 times
