chiefvintage wrote:Well I've given up on the AC installation idea for now. The portable unit was a complete failure as Don and others mentioned it would! But i learned a good lesson on negative air pressure in small spaces,lol! I'll revisit it next spring, since most places I like to camp are either closed, overbooked or too strict with covid madness for my liking. I think a boxed in window Ac unit seems easy enough to put together, utilizing the exhaust port i cut in for the portable unit to be repurposed as an inlet for compressor/condensing coil cooling. Ideally i would like to avoid cutting another stud in the wall framing so if i can find a 5 or 6000btu unit with a condensor coil no wider than 14.5" i think i can make it work.
ris wrote: Not sure how it works just know my a/c is vented into my camper utility room built across the back of the trailer and only had a small amount of water on the floor twice after exploring the UP of Michigan for 4 months.
Richard
foxontherun wrote:Good morning,
I saw your Excel water heater in one of the pictures above. Is your water heater ventless or does it vent out the rear of unit? I am considering mounting one in similar location and I have a side vent in the same location that I thought might work for venting, prefer not to go thru roof. I don't have a problem with using vent-free as I have a MaxxAire fan about three feet away from where the water heater would be.
Also, how do you like that water heater? Anything you would do different about it?
Thanks!
Harry
Users browsing this forum: Bing [Bot] and 14 guests
