Got the cables on, level as I could with only a four foot level. Not considering if the trailer is perfectly level lol
But it goes up rather smooth considering.
I do have similar concerns with the width that the cable gets to but!!! It works
I lowered the bed as low as I want it to go, then ran the cable, Used the turnbuckles to pick up the tension and release the straps. Then raised it up with the drill.
Slick is slick. Now to take it out and paint, finish weld the bearings which I am not even sure I need at the moment. Go with a guide similar to Flboy and the drive system from Brian.
Video to follow after I clean up my welding messes and put some tools away. Also need to get pins to set the bed frame on.
