$200! Yikes! Is it worth it? Or should I look into alternatives? I feel like I could rip the motor out of any fan and have my buddy 3D print the blades for 1/8 the cost of those!
LinearLynn wrote:$200! Yikes! Is it worth it? Or should I look into alternatives? I feel like I could rip the motor out of any fan and have my buddy 3D print the blades for 1/8 the cost of those!
LinearLynn wrote:Does anybody have a reccommendation on sealent for the outside if we cut a hole? I saw some boat repair silicone I was thinking of using, or maybe even tar?
flboy wrote:.. a good small car electric radiator fan motor on a pulse width type variable speed control would rock if you can make that work. You'd have to engineer mounts and etc....
TimC wrote: Search "Case Fans" on tnttt and you'll likely come up with simple and complex uses...I use two 120mm case fans designed for computer cases. They each move about 33 CFM so in my teardrop I change the air once about every 3 or 4 minutes.
Removable cover for stargazing certainly sounds dreamy!! Love that idea.Tomterrific wrote:I see many folks using 12v fans but few suggest passive ventilation. I have one ceiling vent and want to install another above our heads. I've even thought of a diy large vent, removable cover for star gazing.
Tt
