MickinOz wrote:A few questions re: your solar system.
Those Renogy folding kits appear to come with a charge controller. Have you by-passed this to feed "raw" power to the Victron controller?
How is the dual Victron set up wired to the battery, do you only use one system at a time?
My Renogy Rover MPPT controller needs to "see" the battery voltage.
If you have two chargers in parallel do they confuse each other with regard to battery voltage sensing?
I haven't read all your thread - there simply are not enough hours in the day to read everything I find interesting, so I hope you'll forgive me if you covered all this.
Thanks everyone for the lively discussion. I’ll try to answer Mick’s questions here:
1. My first solar suitcase came with a PWM charge controller that has a lithium setting, but no adjustability. The second one I got is the panel only. I bypassed the PWM charger to send all the power from both panels in series directly to the Victron MPPT mounted inside the trailer. I have a waterproof CNLinko coupler on the side of the trailer for the solar wires.
2. The Victron components can all see each other because they form a bluetooth network. Thus, both charge controllers get to know the voltage and temperature readings taken at the battery by the BMV712 monitor.
3. It is fine to use two charge controllers at the same time because they don’t interfere or fight with each other. This should be true even without the Victron network.
4. No worries! Happy to answer questions.
![Thumbs Up :thumbsup:](./images/smilies/econ_thumbsup.gif)
