doug hodder wrote:Duke...if it were me...I'd recheck the center line of the axle that you have indicated...it appears to be set back a bit too far...check some of Andrews specs on axle placement...just an idea...Doug
Nitetimes wrote:I would suggest chamfering the ends of the tube before welding them together, that will give you a good strong joint. Welding the angle to the inside would be a good idea too. Of course a piece of 1/8" plate 6" or so long on the outside wouldn't hurt either. Keep in mind your axle will be back there so getting a good splice is pretty important.
Mike Spicer wrote:Duke
Kind of looks like a Spectrum XLT detector???
But what did You find??
Mike
Aaron wrote:was that a cache? or found seperate? i have been detecting since i was about 10. i have yet to find the gold coins lol. got some nice pieces of jewelry with my minelab excalibur 1000 though. its about paid for itself in a couple of trips! i want to build be a tear drop so i can haul gear into the back woods and pan/dredge gold.
Users browsing this forum: rustyb and 1 guest
