New Build - 6*12 Offroad Toy Hauler
Re: New Build - 6*12 Offroad Toy Hauler
Postby flboy » Thu Oct 07, 2021 1:24 pm
Looks like I gained 6 inches overall. Wow, wasn't expecting that much lift.. maybe 5 inches at most. In any case, now I have to put the SumoSprings on for stability (sway with higher center of gravity) and when these tires need changing, I'll invest in some good all terrain tires.
BEFORE
AFTER
Sent from my SM-N970U using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Thu Oct 07, 2021 2:22 pm
OK, got the SumoSprings installed. Going on a trip next week, so I will see how all this rides.
Don (Flboy)
flboy
Images: 378
Postby flboy » Thu Oct 07, 2021 2:37 pm
Looks like that lift also put the truck and trailer I the same plane as well.
Don (Flboy)
flboy
Images: 378
Axle Flip - Trailer Lift
Postby flboy » Thu Oct 07, 2021 9:29 pm
I made a video on how I went about moving my axle from on top of the leaf springs to under the leaf springs and getting 6 inches of lift for under carriage clearance when off-road. I hope it helps someone.
https://youtu.be/9SmCMNJkmh4
Don (Flboy)
flboy
Images: 378
Postby bdosborn » Fri Oct 08, 2021 7:50 am
Don,
How much does that tank bulge when it's full of water? Do you need to brace the sides or is it self supporting?
Images: 777
Postby flboy » Fri Oct 08, 2021 11:29 am
bdosborn wrote:Don,
Hi Bruce. It does not seem to bulge much at all when full.
I have two of those round foam " pool noodles" at the back between the tank and cab and if you look, they are bent over the top. Also, my truck bed has a thick rubber mat on the bottom, so I think it is well protected from chaffing and movement.
In any case, if I see any bulging that concerns me, I could cut a few 2*4s to the correct height and put them vertically between the strap in front and the tank. That should contain any bulging well if needed. I may still do that just to be on the conservative side, especially if I know I will be spending a long time on rough trails.
Don (Flboy)
flboy
Images: 378
Postby bdosborn » Fri Oct 08, 2021 11:49 am
That's a good idea to use the strap around the middle like that, I think I'll copy that for the van.
Thanks for the info,
Images: 777
Postby flboy » Sun Oct 10, 2021 2:34 pm
Another upgrade! Had these lights for a while, just took the time to install. I can select many different colors.. I tend to like the blue lights however.
Don (Flboy)
flboy
Images: 378
Postby nsfr1206 » Sun Oct 10, 2021 3:05 pm
Nice! We camped Friday night in my parents camper and it has some lights under there. Brightens things up
nsfr1206
Postby flboy » Sun Oct 10, 2021 3:15 pm
Thanks.
Added some inside as well.
Don (Flboy)
flboy
Images: 378
Postby bdosborn » Sun Oct 10, 2021 4:45 pm
Blue light can keep you awake, you might want to dial it to red before bed time:
https://www.health.harvard.edu/staying-healthy/blue-light-has-a-dark-side
Images: 777
Postby flboy » Sun Oct 10, 2021 6:17 pm
Interesting.. I will change the color a few hours before I am ready to go to sleep. Lol
Don (Flboy)
flboy
Images: 378
Postby flboy » Sun Oct 10, 2021 10:00 pm
I've had a few questions and requests to share how I set up the electrical system in my 6x12 CTC. I made a video about that if you are interested.
https://youtu.be/xwYsgocIvwg
Don (Flboy)
flboy
Images: 378
Postby flboy » Mon Oct 11, 2021 1:30 pm
Another upgrade I had and just not installed. A screen back door. Goes on with Velcro and magnets keep it closed. Will allow for great ventilation when camping.
Don (Flboy)
flboy
Images: 378
Postby flboy » Mon Oct 11, 2021 5:59 pm
The LED in cabinet lighting turned out nice. The White setting actually lights up the space well for slightly over 1 Amp. The colors are slightly less.
White is nice
Blue is good for more populated areas. Hard to see from outside, but good enough to see inside. I can also adjust brightness.
Orange is just cool. Kinda like my KTM'S. LOL
Don (Flboy)
flboy
Images: 378
Users browsing this forum: Google [Bot] and 1 guest
