GTS225 wrote:DO NOT haphazardly modify your 12 volt wiring with some makeshift interconnection to 120VAC.
Get a 12vdc power supply to plug into your 120 outlet, and correctly wire the power supply output(s) into your 12vdc wiring.
When running on solar, simply unplug the power supply from the outlet.
Anything else, you run the risk of feeding a solar panel, or other 12vdc equipment a 120VAC charge.
Remember; You, yourself called it a "crazy idea".
Roger
edgeau wrote:Are you going to disconnect the internal AC wiring and connect the socket to DC?
The thing could work as long as you are always the one hooking it up but as soon as someone else comes along it will go wrong : probably dangerously so. I see DC stuff being fried by AC helpfully plugged in for you and it gets worse from there.
tony.latham wrote:Frankly, that sounds goofy.
Just install a Zamp connector on the outside of your cabin and run the wires to the battery.
DairylandOverland wrote:tony.latham wrote:Frankly, that sounds goofy.
I wanted to avoid adding holes to the trailer, but you're right.
Thanks to all for the input!
I wanted to avoid adding holes...
Tom&Shelly wrote:Lots of folks don't have, or want, AC in their tear. If you happen not to want it, you might take out the plug on the outside and replace it with a Zamp (or other) solar connector and replace one of the outlets on the inside with something to connect to your battery.
Unfortunately I don't have a/c ports. I wanted them to possibly add a diesel or propex heater later on, but their supplier that makes the ports went kaput.
DairylandOverland wrote:12v power would be coming only from the Bluetti. I'm not looking to connect the AC and DC systems, just using the shore AC connection as a solar pass-thru. Since there's only one shore connection, there would be no risk of fleeting ac power into the solar panel.
Users browsing this forum: TimC and 3 guests
