$6K 500 pounds (dry weight). Good construction that was load tested by the pros.
=Cosmo
friz wrote:I would insulate it the same way I did my CLC.
Sent from my SM-G965U using Tapatalk
Fitted the foam, glued headliner to foam, glued wrapped foam in place. Spray adhesive for all of it.matphat wrote:friz wrote:I would insulate it the same way I did my CLC.
Did you skin the insulation after you installed it? If so, how did that impact the build, space, and durability of the interior?
Enough to kick condensation and keep me and the Mrs comfortable in the 40s without heat.TimC wrote:That looks great Friz. What do you think is the R value for your walls?
Users browsing this forum: No registered users and 31 guests
