Completely wooden trailer frame for ultralight trailer?
Re: Completely wooden trailer frame for ultralight trailer?
Postby greygoos » Sat Feb 12, 2022 11:13 am
Design_Library/The%20Ultralight%20Chassis.htm Here is a link to the ultralight frame.
greygoos
Postby twisted lines » Sat Feb 12, 2022 11:42 am
I may weld that frame for a box of screws :thinking:
Racking up; And Rapin foam
twisted lines
Postby QueticoBill » Sat Feb 12, 2022 2:08 pm
Yes, that one, thank you. Not sure registration will be easy if it has to be inspected but with a solid ply bottom, I'd be comfortable in or behind it. A ply-foam-ply sandwich base with wood around perimeter and at joints if any, foamie walls and roof, ought to be in the 200 to 300 pound range at 4x8.
QB
QueticoBill
Images: 22
Postby Betonhaus » Wed Feb 16, 2022 9:22 pm
Isn't there a trailer chassis design that is just a triangle? I might be able to swing getting help for that...
Thanks for the advice anyways, I was hoping to see how cheap and light I could get the trailer which is basically a bed on wheels. I can get it under $800 if I salvage a used frame, but I also still want it light enough that my car tows it without struggling.
Betonhaus
