Or, should I just piece all these parts out myself and build this unit as it’s own entity.
Those are kind of my thoughts as well Tony. Electronics are ever changing and something better keeps coming out. I would be “stuck” with this system and to find parts and pieces as they life out or fail could and would be difficult. I was thinking a built system I would be able to replace the parts or pieces as they failed.tony.latham wrote:Or, should I just piece all these parts out myself and build this unit as it’s own entity.
I think that's what you should do for several reasons. First of all, all batteries fail including. So in ten years or so, that box will need an upgrade and you probably can't buy a drop-in battery from them.
Secondly, "25AH 51.2v LIFEPO4 Battery " Are you kidding? 25 amps?. But maybe I'm getting my Ohm's law since it's an odd voltage. But amps is amps. My $200 AGM that should last nearly a decade has 35 usable amps.
Thirdly, that's a monster of a box that I think is designed to be put in the back of a truck bed. It would be a challenge, at least for me, to find a place to put it in a teardrop which would waste a lot of space. It wouldn't be a challenge to find a place for the battery to live and a Progressive Dynamics inverter system to distribute your power.
That's my two-bits.
The pros are their power curve (total power output for a charged battery) seems better than AGM,
And thoughts for or against this idea?
I have read that the flexible panels aren’t the greatest either as they degrade...
tony.latham wrote:...
Calling them all junk is like saying all RVs are junk. This may be 90% true or so until you look at products built by Vistabule or Airstream.
