tony.latham wrote:Either way, you'll have holes for the intake/exhaust.
You might take a peek at Slim's two videos on these stand-alone things:
Onajourney wrote:For what it's worth, I am going to install the one I just bought in the bottom cabinet in the galley and duct it directly thru bulkhead wall. I will drill through floor for both intake and exhaust. Many people recommend getting the intake from inside to recirculate which is probably the most efficient way to do it. Folks also say these little CDHs will cook you out of a teardrop. So that's why I am not recirculating. We shall see.
jakejakejake wrote:here's where knowing a little bit about a lot of things comes in handy! In the marine world they use a "thru Hull" style fitting that looks like this https://www.amazon.com/Zurci-Exhaust-Fi ... th=1&psc=1
Basically a double wall pipe like you would find used for residential gas appliance flue.
I haven't had the chance yet to run my heater (a maxspeedingrods 8kw) so I'm not sure what to expect as far as exhaust gas temperature or if that style thru hull fitting would run cool enough for our foam construction.
I plan to mount my heater in the truck bed forward of the wheel wells in a weatherproof enclosure. Mostly do to limited interior space, but I'm not sure I would do an interior install regardless. Having the combustion and diesel fuel outside just makes sense to me.
dbhosttexas wrote: So... would it be better to mount the heater in the camper, or outside? I.E. inside and route the combustion intake and exhaust outdoors... I am thinking with the heater inside it would be cycling pre warmed air instead of constantly pulling fresh frigid air.
As I go through this I'd like at least the fuel tank outside. Then comes the whole thing about cold and diesel fuel jelling.. Then again I tend to run from that kind of cold..
dbhosttexas wrote:Gelling of the fuel can be an issue, however winter blend fuel should have anti gel already in it. HOWEVER no harm in adding a touch of anti gel...
Gelling of the fuel can be an issue...
Users browsing this forum: Johnny Swank and 4 guests
