Thank you for your reply!noseoil wrote:Just remember, the fuse protects the WIRE, not the device attached to it. Use a chart for run length & wire gauge & you'll be fine. Looking pretty good now.
eLink wrote:I added a 3/4" rib to the hatch wall (making it 1.5" total) to accommodate the wide trim. I kind of wish I had made it even wider.
I'm loosely following Vintage Tech's tip:
https://www.teardroptrailerparts.com/wi ... lding.html
However, I'll be using a 1 1/2" x 1/2" aluminum angle instead of the trim they recommend, because it's flat and not pre-drilled.
eLink wrote:You have brought up some distressing points for me. So I put together my own mockup and have found that the hinge leg and the T-molding will indeed be sitting on top of the molding and squashing down the rubber seal. ...
eLink wrote:Looking back at Vintage Tech's tips... It seems like we'll be ok in either case.
https://www.teardroptrailerparts.com/hurricane-hinge-w-flat-bar.html
I'm facing anther dilemma. I have 2 porch lights, the wires need to stick out to the outside. Do I need to install the exterior skin before wiring? otherwise, it can be a challenge to pull out the wires when install the exterior skin.
tony.latham wrote:I'm in the camp that doesn't believe there's a need for a porch light. But that's not answering your question.
What are you skinning it with? If I wanted a porch light, I think I would run the wires, coil them in an inset hole, mark the spot with a neodymium magnet set flush 1/2" below the wires... and install the aluminum skin. It would be an easy task to locate the wires.
