GPW wrote:TL, Great idea !!!
pchast wrote:Did you bend the pieces together or separately and then glue. I think you may find if you restrain the ends of the piece you're bending it will better conform to the curve. I've used that making wood forms with sheet metal binding the outside.
GPW wrote:Just a note : When bending foam to the extreme , the outside of the bend is most venerable to cracking (Tension) . So the easy thing to do is put some kind of tape on the outside , even cheap packing tape will take the tension loads and prevent cracking while bending . Fiberglass tape while more pricy works the best ... Even with kerfing' , tape works !!!
