Source for sandwich panels?
Postby kludge » Thu Feb 08, 2024 12:32 pm
I'm having a hard time finding any local, or even state-side source for foam core sandwich panels. Fiberglass/FRP preferred, but I'm will consider aluminum too.
Suggestions? Indiana/Midwest?
TIA!
kludge
Re: Source for sandwich panels?
Postby TCJ » Thu Feb 08, 2024 12:37 pm
The only source I found was Boulter Plywood in Massachusetts (https://www.boulterplywood.com/). Shipping would be exorbitant. I ended up just making my own using foam, epoxy, and 2mm okoume plywood. No vacuum bag (that would be best), just weights and a flat table. One advantage of making your own is you can use solid wood cores in places where you're going to attach things like hinges.
TCJ
Postby tony.latham » Thu Feb 08, 2024 12:42 pm
http://www.boreascampers.com is selling them for $540 and I think they are in Colorado.
A bit steep. Me? I'll stick with building my own. ;) Specific to the trailer's needs.
Postby saywhatthat » Thu Feb 08, 2024 12:54 pm
They're so easy to make and cheap to make. we do ploy and foam using $12.00 hardboard as a mold just look out for the expoy liers . No one makes them here to sell to cheap and easy to do your own . About $100 for 4.5 by 9 with 1'' foam with $50.00US setup to make
the way we do it makes a near-indestructible pod you can make your own end caps
all so look at this video https://forum.expeditionportal.com/thre ... 43/page-21
IMG_20220110_163942 s (1).jpg (42.23 KiB) Viewed 939 times
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby saywhatthat » Thu Feb 08, 2024 1:00 pm
end caps for walls1.5 mat 7oz woven 3/4 mat for skins
we have two 8 year old building pods
cut sides lay top on glue end caps . run 4'' wet layup on inside fell gap with can foam done with pod . pods under 200 lbs
saywhatthat
Images: 135
Postby saywhatthat » Thu Feb 08, 2024 5:51 pm
to make the panel take hardboard wax 3 times. paint gel-coat after gel set one laider of 1.5 mat wet out with dollar store roller then 7 oz woven what makes it so strong. then wet layup with 1% catless 3/4 oz mat. shove foam input stepping stones on top. the next day take resin over top of the holes. You can tell if you have any voids then in side 1.5 mat 7 oz woven 3/4 mat that lip on side wall is made by 1.5 offset on your saw .any gap is filed with can foam
https://www.homedepot.com/p/12-in-x-12- ... lsrc=aw.ds
saywhatthat
Images: 135
Postby kludge » Fri Feb 09, 2024 8:34 am
Thanks y'all, but not interested in making my own.
kludge
Postby kd8cgo » Fri Feb 09, 2024 10:49 am
Totalplastics in Kalmazoo, MI carries Coosa Bluewater 26 board and perhaps others: https://totalplastics.com/product/coosa-bluewater-26/
Kerdi board is available for order at many home centers including Lowe's, which usually seems the 1/2" thickness is in stock. A similar product is called Wedi board, carried by some tile/flooring shops and building suppliers. Both products are waterproof boards normally in 4x8 sheets available in many thicknesses, waterproof for wet indoor and outdoor building projects. https://www.masterwholesale.com will put either Wedi or Kerdi on a LTL truck and ship it to you as well - you can see the prices of these boards on their website.
kd8cgo
Images: 21
Postby TCJ » Fri Feb 09, 2024 11:26 am
kd8cgo wrote:Totalplastics in Kalmazoo, MI carries Coosa Bluewater 26 board and perhaps others: https://totalplastics.com/product/coosa-bluewater-26/
Kerdi board . . . never thought of that! Do you know what the skin is over the foam? It certainly is light--7 lbs for a 4x8 1/2" panel. I wonder about the impact resistance though if not covered with tile (which it's designed to be).
TCJ
Postby kd8cgo » Fri Feb 09, 2024 11:42 am
As far as I know, Kerdi and Wedi are both a fiberglass mesh embedded in a polymer resin surface of some kind, Kerdi I think has a fleece on the surface to help anchor thinset, but it should be good for many bonding adhesives, for instance if you were going to surface with filon, laid up flberglass top surface, etc.
kd8cgo
Images: 21
Postby saywhatthat » Fri Feb 09, 2024 11:58 am
for $14,000 are more email [email protected]. you could do your shelf for under $ 1000. are look on ebay for a glue and go pod about $3500 for a glass foam pod
saywhatthat
Images: 135
Users browsing this forum: No registered users and 24 guests
