Elumia wrote:I am curious as to why you framed the steel frame with wood and the then ply on top of that framing. What is the advantage of doing that over putting the ply directly on the steel chassis?
Mark
lvrdrm wrote:born, are you insulating that floor? If not, did putting a wood frame help minimize the amount of drilling to the actual steel frame. How many "fastners" did you actually use to attach the floor? I couldn't tell but did you have gussets welded on the steel frame? Also wondering why you didn't prep/seal your frame before adding your wood floor, might be a little more difficult now. maybe I missed something
