These are the components I am using for my electrical system. The yellow outlet has a built in GFCI and circuit breaker. The power converter and the two plug strips will be pluged into it. The yellow outlet will be mounted in the lower galley with the male plug mounted through the wall to be attached to shore power with an extension cord. The plug will be covered with the gray outlet cover. One plug strip will be mounted in the upper galley area and the other inside the tear. All the 12 volt lights and accessories will be powered by the IOTA converter. I will run everything (12 volt) through a fuse panel. The 12 volt system will be grounded to the frame. I may add a battery to the system at a later date if I feel it is needed.
The only problem is this AC system cannot be easily grounded to the frame. Unless I open up the yellow outlet box and tap into the ground. I not sure if this will work because the GFCI is in the male end of the cord.
My other plan is to carry one of the small outlet testers with me to make sure the shore power I am hooking up to is properly wired and grounded.
Any feedback on this system is welcomed!
http://pg.photos.yahoo.com/ph/tydeanmot ... pg&.src=ph
