A pic for anybody thinking about expandable spray in insulation.
Note this pic is close to half way done. The cans are 4.39 each at Bi-Mart.
del
Yes I did fill in a spot (to the right on both pieces is the bottom) on both pieces.angib wrote:Do you need to fill the bottom of each one, so that it doesn't collect mud and whatever - I'm not sure which way round they go and so if they will trap muck at the bottom.
Andrew
They used to make a non toxic version of the foam that was less money than the toxic, now it is two dollars more . No you do not want to apply this in an enclosed space.dandan wrote:Hi Del,
the up-dates you are posting are looking good.
not sure what they put in those cans of foam where you are
but i know for the UK domestic market, they put lots
of nasties in it to kill any bugs which may try to nest in it.
i reckon on useing astrofoil for insulation cos ive just
insulated my attic with the stuff & got lots spare. jammed
a load behind the radiators in my house & the difference in the temprature of the wall behind it was increadable.
there is an ebay seller over here who sells 4 footwide rolls, 120 foot long
for UK £85 each delevered. thats after he has imported it from the USA !
stay lucky
dan.
It got more expensive than I anticipated, but I did get that part done (spray on insulation) need a bit more flat insulation in the cealing (next year). It is improved over last year for sleeping in the cold, till I open the door to put my shoes on, brrrrr. I am in Kanas now so not much work getting done currently.dandan wrote:Del,
its been a while since your last post,
hope all the insulateing has gon to plan.
looking forward to your next up-date.
all the best, dan. (aka. dandan.)
