Moderator: Sonetpro
tinksdad wrote:I noticed there was only about 50 pounds difference between the two. I was just throwing another option in the ring. Too much spare time on my hands.
The ease of getting a title would probably outweigh the weight difference.
tinksdad wrote:Just a past time when I get bored. I have been thinking about building another lite weight for re-sale to help finance my next one. I'm torn between going with the Paddy Wagon I've sort of all ready started and making a complete left turn and doing a SlumberCoach clone (if I can find enough pictures to work from). My skills are no where near some of the designs I've seen you put up here.
Bobjr59 wrote:Mike how much weight would it add if I insulated it and used a lite covering for the ceiling and I have a 12 volt Norcold I took out of my semi as for power I have a inverter I used in my semi and I was thinking of useing a solar collector aswell as a 1000 watt gen. I'm also thinking that ideal using a 5 gal. water jug and a wash pan for a sink would diffenttlly work I used a simular setup and for heat was looking at using a Coleman heater and I have a light weight two burner stove I'm also looking at using 2 12volt florecent lights one in cabin and one in galley and L.E.D marker lights
