Here's something for you guys to figure out.
Postby Dean in Eureka, CA » Fri Jan 30, 2009 12:08 am
Is it used to set certain types of hose clamps?
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Nitetimes » Fri Jan 30, 2009 12:09 am
Dean in Eureka, CA wrote:Is it used to set certain types of hose clamps?
Nope.
See my last post. Hint, hint, hint...................
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Nitetimes » Fri Jan 30, 2009 12:10 am
BRB - gotta take the garbage out.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby swissarmygirl » Fri Jan 30, 2009 12:12 am
Its used to hold down the thermostat housing if you break the bolt or if you need it for a manifold flange. :thumbsup:
"Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it." - Mark Twain
"The intuitive mind is a sacred gift and the rational mind is a faithful servant. We have created a society that honors the servant and has forgotten the gift." - Albert Einstein
4 Hats Studio
swissarmygirl
Images: 129
Postby Dean in Eureka, CA » Fri Jan 30, 2009 12:16 am
Is it used to insert a helicoil?
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Nitetimes » Fri Jan 30, 2009 12:16 am
It's snowin' again, looks like enough to make the roads $hitty again. The resident female will NOT be happy to see that in the morning!!!! 8) 8) :lol:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Nitetimes » Fri Jan 30, 2009 12:17 am
Dean in Eureka, CA wrote:Is it used to insert a helicoil?
Nope
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Joe G » Fri Jan 30, 2009 12:24 am
Is it some sort of temporary clamp for an exhaust manifold collector flange joint?
Joe G
Images: 25
Postby Nitetimes » Fri Jan 30, 2009 12:25 am
swissarmygirl wrote:Its used to hold down the thermostat housing if you break the bolt or if you need it for a manifold flange. :thumbsup:
I doubt it would work on most thermostat housings. but............
Ok, now I'll explain since Lisa (the girl) :roll: got the closest.
If you break a exhaust manifold stud/bolt at the flange and you can't get to it to drill it or heat it and you need to get it back together now you use this gizmo to clamp it together. The set screw gets adjusted into the hole on the manifold and the big nub fits into the hole on the flange, tighten it up and tighten the lock nut and you are ready to go. :thumbsup:
:D :D :D
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Joe G wrote:Is it some sort of temporary clamp for an exhaust manifold collector flange joint?
Yep, see below you.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Joe G » Fri Jan 30, 2009 12:26 am
WOO HOO!
Joe G
Images: 25
Postby swissarmygirl » Fri Jan 30, 2009 12:28 am
:D :D :D
My father-in-law has used it on thermostat housings....
and I have to confess....the above answer was typed by Honeyman, who has been a mechanic forever (even now is still a part time mechanic).
He said they don't use those anymore.
4 Hats Studio
swissarmygirl
Images: 129
Postby Nitetimes » Fri Jan 30, 2009 12:31 am
:D :D :D
I'm not gonna argue with that, that one has to be 20 or more years old. ;)
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Nitetimes » Fri Jan 30, 2009 12:33 am
:D :D :D
I'm sure it would work on some of them but I know it wouldn't work on most Fords because the housing bolts in the manifold. But anything with exposed bolt ears I'm sure it would work on.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Nitetimes » Fri Jan 30, 2009 12:34 am
Joe G wrote:WOO HOO!
Of course you were second to get it. 8) 8) :lol:
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
