Most expensive item in your build
TV
2
4%
Axle
6
12%
Trailer (Purchased, not built)
27
52%
Trailer (Built, not purchased, excluding axle)
8
15%
Windows
9
17%
Total votes : 52
Postby len19070 » Wed May 26, 2010 8:51 am
I'm with Coop.
Cushions & Covers!
Without a doubt an extremely BIG expense that is never counted on.
Happy Trails
Len
len19070
Images: 24
Postby caseydog » Wed May 26, 2010 9:39 am
absolutsnwbrdr wrote:Had to vote for windows, as there was no door option. I have the prefabricated tinted glass door/window combos. Bought 2 of them... not cheap! About a 1/3rd of my budget :shock:
Same for me.
CD
My build journal is HERE
caseydog
Images: 515
Postby parnold » Wed May 26, 2010 12:28 pm
Trailer $329.00
Mattress $219.00
Wood $180.00
Windows/Doors $130.00
parnold
Images: 302
Postby steve smoot » Wed May 26, 2010 1:22 pm
I have to revise my vote...I bought secondhand windows, so the trailer is now the most expensive item @ $280.... :o
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby Shadow Catcher » Wed May 26, 2010 6:46 pm
The frame (all aluminum) followed by the gas electric water heater.
Postby martha24 » Thu May 27, 2010 12:57 am
Other: my older trailer frame came with 1934 Ford wire wheels. So buying all the reproduction Ford items, i.e., whitewall tires, fenders, rear brake lights was the most expensive part. But that is what makes the trailer. 8)
Martha ;)
martha24
Images: 237
Postby darnis » Fri May 28, 2010 3:02 pm
So far the trailer...since we're just starting, may have to revise it later. It could be eclipsed by the cushions/covers as others have said. What I've just put into replacing the cushions/covers/curtains in the cabover camper has already cost more than the purchased trailer/frame for the td build. Don't expect to need as much for the td and we're still undecided on the doors, so time will tell. :thinking:
darnis
Postby 2bits » Sun Jul 18, 2010 8:26 pm
Yeah this is a hard poll to pull off. I chose the Axle because from the list it was the most expensive, but I would say it was the wheels and tires since I got car size.
I got a great deal on my Aluminum, but I would think that would be a big one for people and don't forget fiberglass fenders too! We aren't even counting wood too, my 4x10 Maple walls alone were $135 each! :?
Thomas
2bits
2bit Member
Postby aggie79 » Thu Aug 26, 2010 1:58 pm
Auminum sheeting - I'm using the "mirror" polished anodized aluminum. For five 4'x10' sheets ti cost me about $750.
Postby Me&T » Mon Oct 25, 2010 8:54 pm
so far our biggest cost has been the trailer ($510) and I'd like to keep it that way. Originally we wanted the pre-made doors that come on the Little Guy trailers, but once we starting looking and couldn't find them cheaper than $280 each, we changed our mind. I'm shopping for metal now, but even that looks like it's come in under half what we paid for the trailer.
Me&T
Postby Arne » Tue Oct 26, 2010 9:38 am
petcool @ $400.00...
no contest, all other items were not even close.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Ptomaine » Sun Nov 14, 2010 11:31 am
My single door was more expensive than the frame. Without the 20% off coupon, the frame would have been higher.
As you grow up and leave the playground where you kissed your prince and found your frog.
Remember the Jester that showed you tears The script for tears.
Ptomaine
Postby PaulC » Wed Dec 01, 2010 12:54 am
I voted windows only because you do not have a door vote. You people would die if you knew I paid $1300.00AUD for 2 doors.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby cracker39 » Wed Dec 01, 2010 12:51 pm
The poll was rather limited on choices. Of those listed, my trailer frame will cost more than my torsion axle, only after adding in the cost of accessories and two quarts of Rustbullt (not counting cost of tires and wheels). The steel itself will be a little less than the cost of the axle. Of the items not on the poll, the cost of my cushions and 2" memory foam topper will cost nearly as much if not more than the frame. The highest cost will be for the lumber, plywood, and paneling to construct the cabin.
Items costing over $200:
lumber, plywood, paneling
frame (steel, accessories,
axle (Dexter #9 torsion)
cushions & covers
Tires and wheels (three each so I'll have a spare)
Dale
cracker39
Images: 233
Return to User Polls
