oz97tj wrote:That all makes sense. I think the foam floor is cool, if it will work. Depending on the spacing of the frame rails, I'm thinking you'll need more than 1/4 ply with the foam.
Do a simple test with some foam and lay it on the floor on top of some spaced out scrap 2x4s. Then you and the wife climb on it. Maybe it's because I'm a fatty, but I was shocked at how much 1/2 ply sagged between my frame crossmembers. Then again, I don't have many crossmembers because I was concerned with saving weight.
So, you can add crossmembers every 16 inches (or closer) to not have any sag in the floor or you use thicker wood for your floor and use less crossmembers. It's probably a wash either way you look at it, but I'd be curious if someone actually figured out weights of the metal used for frame vs wood used for floor.
Then again, if the frame will be a multi use trailer anyway, then more crossmembers may be needed for whatever else you have planned.
Sorry, just thinking out loud...
Conedodger wrote:I think Fridge vans use a foam floor as well so it must be strong enough
