well i did not. hehehe
those are technical questions. i don't do technical. that is your field and others. i just follow what you suggest.
GPW wrote:Might as well , we’ve discussed most everything else here .... So how do you make a cheese cake ... ??? Got any Low Fat cheesecake recipes ... ?
Sorry , I’m Always on a Diet !!!
eaglesdare wrote:GPW wrote:Might as well , we’ve discussed most everything else here .... So how do you make a cheese cake ... ??? Got any Low Fat cheesecake recipes ... ?
actually, just replace the fat stuff with the low/no fat stuff. works the same.
i'll pm 2 receipes. really don't want to get off topic again.
GPW wrote:Oh Thanks !!! I get the blame ...
OK, windows ... Bonnie , what’s the question?
TOWM , You could use tempered glass if it came the right size... I’d just glaze/putty it in like a regular window so you could replace it , if needed ... Oak should be Fine for window frames huh ? Sturdy !!! But if you use Red Oak , be sure to well seal the end grains , cause’ it’s porous ... like a straw...
