Hot Rod...Burning down the house!!!
Re: Power of T, Will the tent fit???
Postby LDK » Sat Mar 03, 2012 4:04 pm
Chris
You're doing a great job on your camper build. It has a very unique profile and the diamond plate and red aluminum really set it off.
Keep up the good work. :thumbsup:
LDK
Re: Power of T, Mocked up the table
Postby Martiangod » Sun Mar 04, 2012 5:10 pm
Kept trying to figure what to do to support the bed.
Had a brain fart that simple would work, so I notched the cross brace for a 2 x 3 with a simple leg in front and over the water tank.
It pulls out 22 inches and hits stops in the water tank cubby
The the back board for the couch lays across in and sits on cleats on wall,
The cleats were previosly installed because I knew I needed them
Holds my 200 lbs+ no problemo
Then I cut down a tabletop I had and mocked it up under the window,
Notice the indefinatly adjustable table leg to level table out if the campsite is not level, 20 tonn should handle that task sufficiently me thinks.
I think it will work out for morning coffee and cards/Yahtzee in the evening
have 2 light Bistro chairs that will probably be used here. Should be able to get up and have a coffee without making the bed back up into a couch.
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby Martiangod » Tue Mar 06, 2012 6:30 pm
Well I really hated how I mounted the switxh for the fan and the battery monitor.
So today i cut a panel Positioned everything and then cut the holes, Still didn't completely like it so got out my trusty knife and chissel and counter sunk everything.
Why use a router when a knife and chissel will do? Not only that it takes longer that way so it killed my afternoon.
Much better...
Battery status and momentary switch for battery mon and on - off - on momentary switch for fantastic fan and I made a switch plate out of Diamond plate and painted black
Barometer and relative humidity
Decided on no clock as I don't wear a watch cause I could care less what time it is, so when I'm camping I care even less
Chris
Martiangod
Images: 432
Re: Power of T, Control Center updated
Postby droid_ca » Wed Mar 07, 2012 11:40 am
Chris those are some nice switch panels what all are the brass gauges that you have there? Keep up the good job :thumbsup: :applause: :thumbsup:
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Martiangod » Wed Mar 07, 2012 11:48 am
droid_ca wrote:what all are the brass gauges that you have there?
Barometer and relative humidity, Just because I had them...lol
Chris
Martiangod
Images: 432
Postby droid_ca » Wed Mar 07, 2012 12:20 pm
so when you have your couch in bed form how much walking around space do you have...enough for someone to mget up and make a pot of coffee? as for the gauges do you plan on putting in more like for solar or anything like that..I think it is amazing that you turned a garbage scow into a land yacht
“Fide Canem”
droid_ca
Images: 176
Postby Martiangod » Wed Mar 07, 2012 1:23 pm
droid_ca wrote:I think it is amazing that you turned a garbage scow into a land yacht
Thanks, goes all the way back to high school Auto Class, when I brought in my 1966 Ford Econoline pick-up that I bought for $50.
Auto teacher says, ya can't make a chocolate bar out of a piece of chit.
Next fall, brought in my trophy from a local car show and told him to put it where the sun don't shine :0
And yup, have 5 feet of floor space with bed down, table still accessable from 2 sides, will eventually have a 30" cabinette with sink and two burner cooktop that will be between the closet/potty wall and edge of bed. So should work out I hope
Would have been much easier to start with a fresh flat floor, but hey, ya work with what ya got
Chris
Martiangod
Images: 432
Postby Martiangod » Fri Mar 09, 2012 2:12 pm
Yucky day out, back to future planning.
The its never done scenario...lol
Would hold a some drawers, kitchen cubby, and counter space, below it would be main counter with sink and fridge and cooktop.
This is of course after using it for staorage all summer then being dragged to Alberta.
Chris
Martiangod
Images: 432
Postby droid_ca » Fri Mar 09, 2012 2:44 pm
Chris so glad your moving out this way your talents are being wasted way out east like that I have so many ideas to talk to you about I just don't know where to start love the animation of your trailer have you seen the trailer called "The Castaway" I found it was very inspiring for trailer ideas.What programs do you use to design the pictures that you do as I've seen some cool images and would like to do a little tweaking of my own.keep up the good job on your trailer :thumbsup: :applause: :thumbsup:
“Fide Canem”
droid_ca
Images: 176
Re: Power of T, Urinal installed
Postby Martiangod » Sat Mar 10, 2012 8:54 pm
Well cut the hole and test fit,
And it fits
Once I fit the handsprayer should be great for washing hair and brushing teeth, seein as I dont have room for a sink :D
Gonna be nice this weekend weather wise so time to get the holding tank in.
One problemo has cropped up though, My stabalizer jacks interfer with the holding tank by about an inch, so off they have to come.
Oh well If I can't get them back there I'll move them to the front and rethink the back jacks.
Lots of rethinkin involved in this project.
Then the boss made me rethink, or not get fed, ever again, soooooooo!!!!!
Instead Seeing as I like food
IFit the throne into its little spot, should work out.
Tossed around porta pot or throne and seein as my knees are getting no better and the wife has had one hip replaced
Image.
She can get stitchin now, and make the curtains for the window and a privy curtain.
Guess the closet is sort of no longer a closet, well its still a closet, a water closet,
Chris
Martiangod
Images: 432
Re: Power of T, Ohhh Poop !!!
Postby Martiangod » Mon Mar 12, 2012 3:50 pm
Got the holding tank installed today
Was pretty tight for this big tank, had to take existing fittings off repair crack and mount new stub and valve, not really where I wanted to have the valve, but the simplest, just behind the back bumper, had to cut out the half moon so a hose can be hooked up
I've got over 13 inches of road clearance on the lowest point of the valve, AAnd I will be going to higher profile tires so shouldn't hit it on anything
Wanted to do the vent up the other side of toilet but ran into a frame member, will elbow back and across then up through roof.
When I put sink in for kitchenette, it will tee into the vent and go into the black tank, unless I find another tank to go between the axels. But one tank should suffice for weekending. Might two way the kitchen sink, so if we are able to, can run it on the ground
Toilet is permanently installed, Just complete vent and the loo is done
Did have to move the stabilizer jacks I had to the front, was just not enuff room with the tank in to keep them on the back. May go scissors on the back, which I hate or possible drop down jacks bolted on the back corners
Chris
Martiangod
Images: 432
Re: Power of T, Closet getting reworked
Postby mckenney56 » Mon Mar 12, 2012 4:01 pm
Nothing like having a thrown handy when the time is right.
mckenney56
Images: 129
Re: Power of T, OH POOP !!!
Postby Martiangod » Tue Mar 13, 2012 3:11 pm
Well got the underbelly on and no black sticky goo required. God I hate that stuff, especially if you need to work down there later, it always haunts you.
Used 2 sheets of Coroplast, Cheap, very light, easy to work with, not sticky, no varsol required or horrible to work in plastic gloves.
Screwed it to the bottom of the frame to protect the styrofoam using aluminum carpet to lino transition strips I had kickin around.
Any bits and piece of aluminum cut offs, your waste would work fine
Another thing is it lessons turbulents under the trailer with a much more areo surface.
Now just need to plug the truck in and hope I didn't hit any of my wireing...., but its all in conduit so hopefully I'm good
Thank god this weather is so nice, been wanting to get that done .
Only thing left to do underneith is wire the brakes and a bit more paint
Chris
Martiangod
Images: 432
Re: Campfx, No Black sticky stuff required and new name
Postby Martiangod » Tue Mar 13, 2012 3:49 pm
Think I'm just going to get another sheet of red aluminum, continue to the bottom, match the charcoal rocker stripe on the truck
Shouldn't cost much to get decals made up
Chris
Martiangod
Images: 432
Postby Martiangod » Wed Mar 14, 2012 7:58 pm
Well, installed the drinking water filter and a temp instal of the tap
FIlled the water tank, hit the pump and checked everything, all good
Then she needed to go shopping, we found a folding chair on sale for her, the blue one, $9, I might get one tomorrow
Rigged up the table semi permanent till I get a floor plug and leg
Then She picked out a Futon for the trailer, goes pretty good
and comphy too
Then in another store she was diggin through a pile of door matts and found the perfect entry matt for the trailer
Just have to put the stink pipe vent through the roof tomorrow and wire the brakes.
Gonna go for a test pull on friday up to Cyprus Lake National park, 60 miles each way, see if it falls apart on the side of the road :)
Burn up all my scrap wood from the build
Now I have to find my coolers and colman black cat heater :beer: :wine:
Chris
Martiangod
Images: 432
Users browsing this forum: No registered users and 23 guests
