Hydronic Heater
Hydronic Heater
Postby Martiangod » Tue Mar 27, 2012 8:58 pm
Well decided to do some testing tonight, coiled up som 3/8 copper refridgerant tubing using a piece of 3"ABS, about 25 feet I had kickin around.
Cut a 4 1/2 inch hole in botton of plastic pail then mounted the 120 mm computer fan
Drilled two holes to pass the ends of the copper through the bottom of a plastic waste basket.
Put some rubber tubing and fittings to hook up to laundry tap.
Powered up the fan with a power pack and hooked the rig to the tap and turned on the hot water
Had hot air blowing within a minute. Don't have a thermometer here but felt like it was around 80 - 90 degrees.
Nice and quiet.
Then I shut off the hot and turned on the cold water, nice chilly air in a matter of a minute or two.
So I think I'm going to go ahead and source a heater core for a car and a 12 volt circulation pump, don't think a Shur flo can handle hot water, and they're noisy anyhow.
This should give me a cheap heat source, seeing as I have hot water on board, and with a couple of extra valves drawing and retuning to the fresh water tank, I'll have cheep air cooler also
A thermostat and selonoid should be able to control the pump and fan easily
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Re: Hydronic Heater
Postby GuitarPhotog » Tue Mar 27, 2012 9:27 pm
Chris,
I pump hot (not boiling) water in my home brewery with this. It has lasted 20+ years.
http://www.grainger.com/Grainger/DAYTON ... Pid=search
It's not self priming, and it will cavitate like crazy if the water is boiling or close to it (190F+), but it's affordable, durable, and available.
:beer:
<Chas>
GuitarPhotog
Images: 55
Re: Hydronic Heater
Postby Martiangod » Tue Mar 27, 2012 9:54 pm
Thanks, I'll look into something like that, shouldn't be over 140 degrees, if I have it even that hot, as solar circulation pumps are pricey
Chris
Martiangod
Images: 432
Re: Hydronic Heater
Postby Socal Tom » Wed Mar 28, 2012 7:20 am
shurflows are used for showers in RVs, and your system isn.t much different excpet that you push the. water back to the tank nstead of to the drain. i suggest a solenoid valve and a thermostat to make sure you are getting max heat from the water and not just warming your water tank.
Socal Tom
Re: Hydronic Heater
Postby Martiangod » Wed Mar 28, 2012 7:25 am
Socal Tom wrote:shurflows are used for showers in RVs, Tom
The shur flow is pumping cold though, preasurizing the hot water. May test it cause I have a spare though :twisted:
Chris
Martiangod
Images: 432
Re: Hydronic Heater
Postby Socal Tom » Wed Mar 28, 2012 11:22 am
I thought that is what you were doing, pressurizing the hot water tank with cold water, then letting is push through the heater...?
Socal Tom
Re: Hydronic Heater
Postby Mikka » Wed Mar 28, 2012 11:41 am
PrincessAuto.com has cores and pumps. Depending on elevation of various component of the system, you may require a pump with head capability,
Mikka
