bushido41 wrote:Hello Everyone,
I have a PD4045 installed on my TTT, the AC side works great, but I have a few questions about the DC side.
1. The installation manual(which has a lot to be desire) mentions to connect the negative side directly to the PD4045. What happens to chassis ground?
2. The battery connection wires are 10 AW, a bit thin for my taste, when we are talking direct connection to the battery. I know the PD4045 is rated for 45 Amp but just curious.
3. Do you guys recommend a cutoff switch?
My main concern is the negative side connection of the battery, connect directly to chassis or PD4045?
Thank you in advance for your comments.
Shadow Catcher wrote: Maximum power for 10Ga is 55A according to the American Wire Gauge and AWG table and that is what I have used in ours.
mustangcats wrote:I did a lot of research before connecting my WFCO 45 amp power supply and it was advised not to connect the AC ground to the trailer chassis.
8ball_99 wrote:You always bond the ground from AC to the the frame.. That way if you have a hotwire make contact with the frame the current has a path to ground.. If you don't do this and a hotwire contacts the frame when you step in our out of the trailer you could become the path to ground..
H.A. wrote:A few posts above suggest letting the safetychains drape upon the earth as added grounding safety.
While its a fair idea and shows a users concern, At best its an urban legend / campground myth.
In reality would be so minimally effective to be not at all helpful as an added chassis grounding.
