Offroad stabilizers
Moderator: Sonetpro
Re: Offroad stabilizers
Postby droid_ca » Mon Oct 22, 2012 12:19 am
stomperxj How big are your tires on that as I'm looking at 33s
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby stomperxj » Mon Oct 22, 2012 12:31 am
droid_ca wrote:stomperxj How big are your tires on that as I'm looking at 33s
I am running 31's in a spring over axle configuration. Frame height is approx 23" empty and I can lift the tires off the ground pretty close to 6". Your tires would effectively put your frame 1" taller than that (30.7" tire vs 32.7" tire... 2" height dif divided by 2) so the longest BAL jacks they sell would surely work I would think... and you could always mount them lower on the frame by an inch since they are so low profile when in the travel position...
stomperxj
Postby droid_ca » Mon Oct 22, 2012 12:38 am
I like that motorized unit that they have for them just thinking that it might be good for other things as well like possibly a slide out or something but I might go with a airbag on my suspension as well still debating my friend has lots of stuff at his place so we are going to start and pick through some of the treasures...Thanks again for the info
“Fide Canem”
droid_ca
Images: 176
Postby Austear » Sun Nov 04, 2012 4:47 am
Google al ko bigfoot legs. Got them on mine.
Austear
Postby stomperxj » Sun Oct 26, 2014 4:21 pm
droid_ca wrote:
stomperxj wrote:
How far off the ground is your frame? I have no problem lifting my tires 6" off the ground and I have about 23" to the bottom of my frame. The long BAL stab jacks are pretty nice.
well that sounds like they should work do you have a part number for them or what they are called exactly so i can look into them...Yhanks
http://norcoind.com/bal/products/consum ... jack.shtml
stomperxj
Postby ArkansasDon » Wed Feb 05, 2020 5:19 am
I installed the 28" Bal C Series 4000lb jacks with the pads. I run 30" General Grabber ATX's on my trailer w\ 24 inches of chassis ground clearance.
2019 Runaway Range Runner Offroad Build
viewtopic.php?f=50&t=72442
ArkansasDon
