droid_ca wrote:So I did an experament today and the arch piece for my trailer is 3 lbs for a 10 foot chunk
it is a 10 foot long of 1 1/4 PVC pipe I'm going to not only use it for my water tank but I'm also going to use it for my roof trusses and what not
M C Toyer wrote:droid_ca wrote:So I did an experament today and the arch piece for my trailer is 3 lbs for a 10 foot chunk
How do you plan to fill the tube/tank? How will you prevent from freezing?
M C
biziedizie wrote:The marble won't crack if you put a Kerdi product under it and use mastic, also a good rubber membrane works well too. Calk you perimeter and use a mortified grout or better yet a silicone grout.
biziedizie wrote:Cultured marble suxs, go with the real stuff, it's bullet proof if installed right.
