Teardrop for sale, 5x9 ~SOLD~
Postby HABSFAN2006 » Tue Aug 18, 2009 10:00 am
Unfortunately, I will have to sell my teardrop. It is a homebuilt, I love how spacious it is inside, and how light it is to tow. Have only used it a few times, and there is some work to be done to finish it. Hopefully someone will be willing to take this project on with only a little of the easier work left to be done to finish it, and really have it customized to how they want it. Here is some of the info, any questions, please ask!
-2x1x1/8 welded steel frame.
-2500lb axle/springs
-1" plywood walls good one side on inside & varnished.
-5/8" floor & shelf dividers routered in walls at all points, glued and screwed.
- All fasterners are stainless steel, including box to frame carriage bolts.
-hard foam insulated roof
-.040 aluminum sheeting with aluminum trailer/rv mouldings
-TD windows & galley hinge
-12v wired for lights & accessories in middle inside cupboad.
-54" x 76" inside dimension
-4" bedding foam
-stained/varnished pine inside cupboards (& shelves), completed.
To be completed is:
mouldings around windows on inside
mouldings over some joints/corners on inside
galley cupboards / mouldings / flooring
Asking $3700.
Image :) :)
Life is an experience... Learn from it!
http://www.mikenchell.com/forums/album_ ... er_id=9012
HABSFAN2006
Images: 28
Postby Rvankeur » Tue Aug 18, 2009 3:07 pm
It looks very nice. Unfortunately, we're a bit of a distance from Ontario (although we do enjoy visiting it at times). Is your price US $3700 or CDN $3700, for those who might actually be in a position to purchace?
Rose and Ed
Rvankeur
Postby wanders » Tue Aug 18, 2009 6:21 pm
Great job on the tear. Somebody needs to jump on this one!
Wally & Cathi
Director- Old Dominion Tearjerkers
Pied-A-"Tear"
wanders
Images: 23
Postby HABSFAN2006 » Wed Aug 19, 2009 7:27 pm
Thanks guys.
I am asking $3700 CDN, but I would accept USD also 8)
How far is NJ? :D
Are you looking to buy?
Thanks for looking ..
HABSFAN2006
Images: 28
Postby Rvankeur » Thu Aug 20, 2009 9:00 am
We're probably about 10 hours from Ottowa. We actually got engaged ON the Ottowa (river) 5 years ago. :)
We're at the beginning stages of trying to decide between building and buying. Still need to figure out what it is that we're looking for in a TD, but hey, if you're in the area anytime, I'm sure I can get Ed to come look at it. 8)
Good luck,
Rose
Rose and Ed
Rvankeur
Postby Deryk the Pirate » Sat Aug 22, 2009 10:14 am
Looks nice but how much does it weight?
Deryk the Pirate
Images: 158
Postby HABSFAN2006 » Fri Aug 28, 2009 9:45 am
Deryk the Pirate wrote:Looks nice but how much does it weight?
AS IS unfinished I have calculated the weight being 900lbs.
Tongue weight is roughly 100lbs.
this will change as it does get finished.
Finished / loaded weight might be around 1100lbs
and tong weight 100-150lbs
( a lot of the weight will be added behind teh axle)
I often pickup the front and roll it around the yard alone without too much trouble(which is really nice with a teardrop).
My 14hp lawn tractor moves it up my huge hills :lol:
So there's no problem for any 4cyl. car to pull this trailer.
Thanks for lookin...
HABSFAN2006
Images: 28
Postby HABSFAN2006 » Fri Oct 02, 2009 11:09 pm
~SOLD~
Thanks for looking :D
HABSFAN2006
Images: 28
Return to For Sale/Wanted
