Aluminum sheeting in North Texas
Postby Fishingtomatoseed » Tue Jun 04, 2013 5:57 pm
Just thought I would share a place in North Texas that will cut aluminum sheet. This is a semi trailer repair shop www.dallastrailer.com I emailed them today looking for wide aluminum however long you need it and they came through. It is mill finish, .050 thick, 103" wide and up 700' long if you need it. They use it for the roofs of the semi trailers. The phone number is (972) 579-9027 and talk to Tom Henson. I do not know if they will ship. But the price for the aluminum is a lot less than what I have found else where.
Fishingtomatoseed
Images: 9
Re: Aluminum sheeting in North Texas
Postby aggie79 » Wed Jun 05, 2013 7:04 pm
That's good info Clint. Thank you for posting it.
Postby doug hodder » Wed Jun 05, 2013 9:53 pm
I don't know what they charge in Texas, but here in Ca...that material in .040 is 12.86 a running foot. For those of you that haven't used full length material like that, it can be cut easily with a carbide blade in a circular saw, stick a sheet of styrofoam under it when you cut it. Doug
Postby Fishingtomatoseed » Thu Jun 06, 2013 7:08 am
I believe he quoted 12.72lf.
Fishingtomatoseed
Images: 9
Postby planovet » Thu Jun 06, 2013 10:44 am
Yep, they have all you need. I think Vairman has used them in the past also.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Fishingtomatoseed » Sat Jun 08, 2013 12:27 pm
I wish I would have found this while I was building mine and not used the ABS sheeting. Didn't notice it till I got home but the wind got under one section and took the whole sheet off the roof. [PENSIVE FACE]
Fishingtomatoseed
Images: 9
