Newbie question about wheels
Postby Retroguy » Sun Jul 26, 2015 6:57 am
I plan on building a tear on a Harbour Freight trailer or like it. Will I be able to switch out and find wheels that fit that have a vintage feel?
Below shows shows the generic trailer wheels. I prefer to have something like the look of the wheel on the tear drop trailer shown. Any recommendations on trailers that will accommodate that?
Retroguy
Re: Newbie question about wheels
Postby martymcfly » Sun Jul 26, 2015 4:12 pm
Us wheel makes a wheel that looks a lot like the wheel on the trailer on top. I don't know if they make a 4 lug. her is a link.http://www.uswheel.com/products/chrmsmoothie You may be able to use an adapter to go from 4 lug to 5 lug.
martymcfly
Postby Vedette » Sun Jul 26, 2015 4:47 pm
By all means go 15" wheels!
Wheels Vintques makes great wheels too! :thumbsup:
But you should think about a home built Chassis with a Dexter Torsion axle???? :thinking:
You will be way happier down the road.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Midget » Sun Jul 26, 2015 5:13 pm
I get my wheels from Summit Racing. I went through them for the artillery wheels for the Benroy Woody. They are made by US Wheel.
If you have the lug stud measurements you can look on Summit's web page to see if they have one that will fit.
Midget
Images: 91
Postby dogscats » Sun Jul 26, 2015 6:35 pm
I just ordered from Rockwell 2ea oem 15'' wheel with the big hole and 2 hub caps part 4650 steel . will paint the wheel and add a outer chrm. ring.
Wheels $31.00ea
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby Retroguy » Mon Jul 27, 2015 6:40 am
Cool, thanks for the info.
Retroguy
Postby angib » Mon Jul 27, 2015 7:59 am
You need to investigate wheel offset and width too - HF trailers don't seem to have a lot of clearance between the inner sidewall of the tire and the frame rails, so if you fit a wider wheel or one with offset, it may foul the frame rails. On the other hand if you get a wheel with positive offset so that it clears the frame rails, it will overhang the wheel bearings - no great problem if your trailer weighs a lot less than the hubs can carry.
angib
5000 Club
5000 Club
Images: 231
Postby martymcfly » Mon Jul 27, 2015 8:50 pm
A couple of side notes. I see your HF trailer has a 5 lug wheel. I didn't notice that earlier. If you want white walls like in the picture, JC whitney has wide whites for vw beetles. Or if you use a trailer tire, you could look at portawalls.
martymcfly
Postby Retroguy » Mon Jul 27, 2015 9:20 pm
Just to clarify, those are just stock pictures off the internet, I have not bought a trailer yet. I feel I need to get all my thoughts together first before I start. I want to make sure I pick the right trailer first. Can I add 15 inch wheels to a 5 lug trailer. I'm am not knowledgeable about trailer wheel anatomy :crazy:
Retroguy
Postby Jack Olsen » Mon Jul 27, 2015 11:49 pm
For more clarification, lug patterns are different for different hubs and different wheels. Here's a page with a lot of info on it:
http://www.crawlpedia.com/bolt_patterns.htm
The short version is that you can't mix and match wheels and hubs, even when it's the same number of lugs. You have to learn the pattern of your hub and shop for wheels accordingly.
Offset (the distance from the vertical centerline of the wheel to the vertical line of the mating surface of the wheel center) is another issue with cars, but most trailer wheels are zero offset.
Jack Olsen
Postby Retroguy » Tue Jul 28, 2015 7:35 am
I guess I have a lot to learn. I was hoping somebody was going to tell me exactly what to buy copy some links and also send me some money. Just kidding I don't need the links. :D .
Retroguy
