How hot does back of tankless water become
Postby saywhatthat » Tue Jan 29, 2019 12:21 am
Picture rail.jpg (13.65 KiB) Viewed 786 times
I went partners and received 20 sets of the preform railtop / trailtop kits and 400 running feet / 122 meters of railing . As I like to add side boxes made out of this .One with drop down sink /food prep . The other with a eccotemp L5 tankless water heater . Don't want the fiberglass to burn. If you have one do you think wood may burn behind the unit. I like the boxes to be 9 in / 23cm deep .What your though on this? :campfire:
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Re: How hot does back of tankless water become
Postby GPW » Tue Jan 29, 2019 10:03 am
You mean like this ? How does that all fit together … ??? Isn’t there an insulated metal shield you can use for that ??? :thinking:
Postby saywhatthat » Tue Jan 29, 2019 10:41 am
Think rain guttered at your house .You just cut and bond.
Had not even thought of that. Just thing a flat sheet metal would get to hot and need to place thick spacers .
comment est-ce que tout cela va ensemble
Pensez à la pluie gouttée chez vous. Vous venez de couper et de lien.
N’y at-il pas de bouclier métallique isolé que vous pouvez utiliser pour cela?
Je n'avais même pas pensé à cela. La seule chose qu'une tôle plate atteindrait une température élevée et aurait besoin de placer des entretoises épaisses.
saywhatthat
Images: 135
Postby GPW » Tue Jan 29, 2019 5:37 pm
WE recall seeing an insulated metal wall protector for wood stoves … but that was some time ago …
Postby Atomic77 » Tue Jan 29, 2019 6:37 pm
Mine is in a Cedar closet that is lined with fire board and vents to the exterior. We used it for an entire season with no issue. Oxygen sensors never kicked, nor did the CO2 sensor. Flawless operation.
Sent from my SM-N950U using Tapatalk
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby Karen Clancy » Tue Jan 29, 2019 10:01 pm
How about using 1/2 cement board behind the unit .
Karen Clancy
Postby Atomic77 » Wed Jan 30, 2019 11:06 am
Karen Clancy wrote:How about using 1/2 cement board behind the unit .
That's basically what mine is, it's just specifically made for fire retardation
Michael
The Astroliner
Atomic77
Images: 309
Postby saywhatthat » Thu Jan 31, 2019 10:00 pm
Karen Clancy worried that it might crack
GPW thank you for the input
Atomic77 nice looking.. Will be ashamed to show mine. Just a old box after looking at yours
saywhatthat
Images: 135
Postby Atomic77 » Fri Feb 01, 2019 1:08 pm
saywhatthat wrote:Karen Clancy worried that it might crack
Honestly, it really doesn't get very hot other than at the vent. I think I was overly worried about heat when in reality the hot water only runs for seconds at a time. The shower is the biggest concern and even so, it's the vent pipe that's hot. The main concern is that it's vented to the outdoors because it puts out CO and also that it gets fresh air to it so the low O2 sensor doesn't kick it off
Michael
The Astroliner
Atomic77
Images: 309
