Anyone have a light weight tounge jack design?
Postby Buster1903 » Sun Jul 11, 2021 6:22 am
I'm in the prosses of building a ultra light TTT and the tounge jack is a prime location for weight savings. Actually the whole leveling/stabilizing system is. the commercially available legs and jacks are all steel, heavy, and far stronger then I need.
With my old TTT I've used thin steel jack stands and a HF swing tounge jack. It all worked But, I'm looking for a better, easier and lighter solution.
Any Ideas??
I'll know where I am when I see the tree shake on the map
Buster1903
Images: 31
Re: Anyone have a light weight tounge jack design?
Postby QueticoBill » Sun Jul 11, 2021 11:57 am
For a little work, get a speed rail flange - https://www.buyrailings.com/product/wal ... lange/1644 - an a piece of aluminum tube and a wrench. Put a foot on the tube - welded plate or another flange - and maybe change out the set screw for a hex head bolt or get a t- handled allen wrench and an extra. You'll have to lift but shouldn't be hard if truly light weight.
QB
QueticoBill
Images: 22
Postby alaska teardrop » Sun Jul 11, 2021 6:57 pm
The jack is a 750# Bulldog. The geared shaft retracts up flush to the frame & the wheel drops out, leaving nothing to hit on uneven ground. With the rear corners of the trailer blocked, the jack will lift the trailer tires off the ground.
The jack weighs 7# w/o wheel. Found at Tractor Supply store.
alaska teardrop
Postby Buster1903 » Fri Jul 16, 2021 5:43 am
Thanks, both great suggestions!
You hit either end of my ideas. 1) the lightest thing that will hold the tong up with adjustable height and 2) just find the lightest purpose built tongue jack available.
I think it will come down to how I feel when it comes time to make a choice. At the moment I'm a little overwhelmed by how much I'm fabricating from scratch, and I have a hard deadline of Sept. 15th. will let you all know how it turns out.
Buster1903
Images: 31
Postby friz » Sun Jul 18, 2021 7:32 am
No jack for me. I use an old jack stand with a ball attached. Just move things by lifting the tongue by hand.Image
Sent from my SM-G965U using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Postby Pmullen503 » Sun Jul 18, 2021 8:05 am
Great idea!
Pmullen503
Images: 67
Postby JunkMan » Sun Jul 18, 2021 5:55 pm
friz wrote:No jack for me. I use an old jack stand with a ball attached. Just move things by lifting the tongue by hand.Image
Looks like it will work as a theft deterrent too if you lock the coupler closed on the jackstand. :thumbsup:
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby Buster1903 » Sat Jul 24, 2021 1:51 pm
LOL, I have the exact same jack stands, these are the thin steel stands I have been using for my old trailer.
I like the ball idea. I will probably start with something simple like this, I can always modify it later if needed.
Thanks Friz
Buster1903
Images: 31
Postby gudmund » Sun Jul 25, 2021 11:23 am
use the same 'jack stand' setup when parking mine for the winter. Works great!! :thumbsup:
gudmund
Images: 39
