WANTED: The Simplest Solar Setup
Re: WANTED: The Simplest Solar Setup
Postby Shadow Catcher » Wed Jan 05, 2022 2:45 pm
185W High voltage (48V) into a Morningstar SunSaver MPPT controller feeding a 150AH Lifeline AGM basically trouble free for 14 years (replace battery at 10 years (still in use). Powers a Waeco/Dometic fridge, lights, chargers TV/DVD SXM radio etc. I think you are wise in choosing components and building your own.
837718377383774
Postby Staryder61 » Wed Jan 05, 2022 8:54 pm
Hi y'all,
I'm in the same boat as Dahlia47, as for needing a solar system. The simpler the better.
So, keeping track of this thread.
I may have put the horse before the cart, because I have already bought a battery and now looking for the rest to hook up.
(Battery I purchased, is a Diehard Platinum H8 AGM 95 amp hours).
Not looking to take over this thread, just have a couple questions also.
What is the difference between a PWM Controller and a MPPT Controller?
And would the following system work with the battery I purchased?
https://www.amazon.com/Renogy-Monocryst ... 05-20&th=1
Thanks in advance for any information, y'all could give me.
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby tony.latham » Thu Jan 06, 2022 12:14 am
That system will work fine.
MPPT controllers are more efficient than PWM controllers. I find that the PWM controllers do a fine job. MPPT controllers are generally too big and expensive. For the extra money, you can buy a second panel.
Postby Staryder61 » Thu Jan 06, 2022 12:24 am
Thanks Tony, I'll keep looking at the renogy systems then. And yes, I noticed the difference in the prices between the controllers. Did you also go with the renogy battery?
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby tony.latham » Thu Jan 06, 2022 11:02 am
I have a VMAX battery. :thumbsup:
Postby Staryder61 » Thu Jan 06, 2022 1:51 pm
ok, Thanks again Tony :thumbsup:
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
