And would the following system work with the battery I purchased?
tony.latham wrote:And would the following system work with the battery I purchased?
That system will work fine.
MPPT controllers are more efficient than PWM controllers. I find that the PWM controllers do a fine job. MPPT controllers are generally too big and expensive. For the extra money, you can buy a second panel.
Did you also go with the renogy battery?
