where should I look for this gasket?
Postby TheresaD » Sat Jun 25, 2011 3:42 pm
I need to replace the rubber gasket around the skylite in my ttt. It's a 14 x 10 skylite. I checked vintage trailer supply but I think because my trailer is european the size may not be a common one around here.Does anyone have any suggestions as to where I can look here in the U.S. for this? I'm hoping I can get one here. If not I'll have to see if I can get one from the U.K. Here's what it looks like.
All The Best,
Theresa D.
Tearjerkers Great North Woods Chapter Director
68 Sprite 400
47 KIT Companion
146633
TheresaD
Images: 54
Postby parnold » Sat Jun 25, 2011 4:39 pm
Theresa, you may be able to make a gasket. You'll have to determine what the cross section looks like. You can then buy 5' or so, cut to size and glue it in. Bonding gaskets is pretty easy.
Try googling rubber weatherstrip for ideas of what is available.
parnold
Images: 302
Postby Maverick71 » Sat Jun 25, 2011 8:24 pm
Howdy,
For rubber seals of all types and weatherstripping, go to The Minor Rubber Co. Carrolton, TX or www.minorrubber.com to puruse their catalog of diffenent types and cross sections.
To stop insidious leaking and freezing of door seals, I selected their refrigerator door seal with a compressive section and a labyrinth face. Believe me, no more problems with enclosure doors for Diesel and gas turbine gen sets from locations in the Arctic to those of Saudi Arabia.
Incidentally, the proper noun of Diesel should always be capitalized because it is the surname of R. Diesel, the German inventor of the Diesel engine.
Take care,
Maury
Maverick71
Postby Rvankeur » Wed Jun 29, 2011 6:50 am
Maverick71 wrote:Howdy,
Take care,
Maury
Good to know, our son is at trade school learning about Diesel generators.
Rose and Ed
Rvankeur
Postby mechmagcn » Wed Jun 29, 2011 3:09 pm
Another site to check out is http://www.steelerubber.com/?section=3 They have a large selection of weatherstrip products.
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby planovet » Thu Jun 30, 2011 8:20 am
McMaster-Carr has just about every seal or gasket you might need. :thumbsup:
http://www.mcmaster.com
ImageMark (& Cindi)
planovet
The Cat Man
Postby Pottercounty » Thu Jun 30, 2011 5:57 pm
1" split pipe insulation...
best, Tim
Those are my principles. If you don't like them I have others.
Groucho Marx (1890-1977)
Pottercounty
Images: 20
Postby TheresaD » Thu Jun 30, 2011 10:59 pm
Ok.. so pardon my ignorance on this but... don't I have to find the exact same kind of gasket or can different types be used to achieve the same goal? Do they seal the same way? I thought I was going to have to find a rubber gasket, the same as what was originally on my trailer, that was pre-formed into the rectangular shape to fit around the skylight opening. Maybe not so much? Thanks for all the tips. I'll check out all the links.
All The Best,
Theresa D.
68 Sprite 400
47 KIT Companion
146633
TheresaD
Images: 54
