5x8 PLYWOOD
5x8 PLYWOOD
Postby Tychi15 » Sat Nov 03, 2012 2:22 pm
Howdy yall i am currently building my own Teardrop with plans i found online but i want to make it a little bigger on the inside. Does anyone know where i could find some 5x8 plywood i know it exists i just cant find a place to get it from. I want to make the walls one solid piece instead of cutting down and connecting two 4x8 pieces. Thanks for the help :)
Tychi15
Images: 16
Re: 5x8 PLYWOOD
Postby grant whipp » Sat Nov 03, 2012 4:45 pm
5x9 is typical ping pong tabel stock ... try to source it from an independent lumber yard, not a big box store. BTW, you didn't say where you live, so folks in your area can't point you to a source they might know. Good Luck, and ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Re: 5x8 PLYWOOD
Postby Tychi15 » Sat Nov 03, 2012 6:56 pm
That's a great idea I've made a ping pong table before i should have remembered that. I live halfway between Rockford and Chicago so if anyone knows of a place that would be great :)
Tychi15
Images: 16
Re: 5x8 PLYWOOD
Postby pete42 » Sat Nov 03, 2012 9:07 pm
way back in another century we use to fly our plane to the EAA fly-ins held in Rockford.
the one in OshGosh is nice but Rockford was more friendly or it seems to me.
but I do get to visit relatives in Appleton now.
pete
pete42
Re: 5x8 PLYWOOD
Postby Tychi15 » Sat Feb 09, 2013 1:10 pm
I finally got my plywood I guess 5 by 8 is used for tabletop construction my local lumber shop in Woodstock il had it to order thanks for the help :)
Tychi15
Images: 16
Re: 5x8 PLYWOOD
Postby Wild Bill » Sat Feb 09, 2013 7:08 pm
Good luck with your build from Aurora, Il. Lots of events going on around the area for campers, I will send you a PM. Bill
Beavers are Naughty!
Wild Bill
Images: 63
Re: 5x8 PLYWOOD
Postby Tychi15 » Sun Feb 10, 2013 1:21 pm
Cool look forward to it :)
Tychi15
Images: 16
Re: 5x8 PLYWOOD
Postby Vedette » Sun Feb 10, 2013 1:49 pm
Build Picture??? :pictures:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: 5x8 PLYWOOD
Postby Tychi15 » Sun Feb 10, 2013 2:21 pm
My computer is on the fritz now so I'm using an old iPad without a camera so once that's fixed hopefully I will get some pics up :D until then I only have the floor built and the frame of the walls and the doors cut out. It's hard building in a garage with no heat in Chicago in the winter :cry: slow and steady wins the race though :)
Tychi15
Images: 16
Re: 5x8 PLYWOOD
Postby Vedette » Sun Feb 10, 2013 2:27 pm
I know the feeling.........and I have a large heated shop!
Keep up the good work. We will wait for your pictures.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
Re: 5x8 PLYWOOD
Postby Tychi15 » Sun Feb 10, 2013 5:51 pm
Ok so I got annoyed and did pics from my smart phone it was annoying but I have built pics up to where I am at now :)
Tychi15
Images: 16
