Opinions on taking your trailer through a drive-thru
Postby Woodbutcher » Sun Oct 27, 2013 7:46 pm
I sometimes see guys with landscape trailers in line. Only once have I pulled the teardrop through a drive-thru. There was no place to park and I was real hungry. What do others do?
Woodbutcher
Re: Opinions on taking your trailer through a drive-thru
Postby Corwin C » Sun Oct 27, 2013 7:54 pm
My initial reaction to this question is why would you go through a drive through when there's cast iron in the galley?
To answer your question though, it would depend upon the layout of the drive-thru. If it's a straight line or has gentle curves, I don't see an issue, but remember that trailers don't always follow right in the tracks of the tow vehicle. Don't get yourself in the situation where you're caught between curbs and a building or something and can't negotiate a corner.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby eamarquardt » Sun Oct 27, 2013 8:10 pm
Corwin C wrote:My initial reaction to this question is why would you go through a drive through when there's cast iron in the galley?
Ditto.
As my "uncle" taught me "the plan depends upon the terrain and situation". Just make sure you understand the situation and terrain before acting.
Gus
eamarquardt
Images: 150
Postby Wolffarmer » Sun Oct 27, 2013 9:13 pm
This is one reason I build my trailers so the wheels of the trailer are close to the same track as the intended TV. I do not have to worry as much about the wheel sticking out very far. I have taken it through drive throughs, fast food and banks. Two weeks ago I had to retrieve my broken down car with a normal car hauling trailer behind my 1989 Mazda pickup. Man that trailer stuck way out. Luckily it was not far and on county roads.
Randy
Wolffarmer
Images: 309
Postby halfdome, Danny » Sun Oct 27, 2013 9:46 pm
I always scope out the drive thru before making a run for it.
We've been through a lot of drive thru's without any problems but I pay particular attention to where the teardrops wheels are at all times, swing wide.
If you don't feel comfortable with drive thru's and teardrops don't do it.
:D Danny.
halfdome, Danny
*Happy Camper
Images: 252
Postby Roly Nelson » Sun Oct 27, 2013 11:32 pm
Yep, I do it all of the time, anywhere my car tires can go, my TD trailer tires can go also. Mine's a 4x8, so that helps. Swing wide.
Roly~~
Roly Nelson
L'il Ol' Woody Builder
Postby Vedette » Mon Oct 28, 2013 1:00 am
I too have been thru with Miss Piggy.
But, my golden rule is: I do not drive into places I can't back out of with the trailer.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby PKCSPT » Mon Oct 28, 2013 2:14 am
I have taken mine through, just be prepared for the usual questions.
121172 116946 159644
PKCSPT
Images: 61
Postby RioWilson » Mon Oct 28, 2013 5:58 am
I always take mine through. It helps me appreciate my TD after many years with a 25' TT and an F350. I like being able to sneak through with my VW Jetta and TD and get on my way. Even better is to find a nice rest stop or overlook and make lunch in the teardrop, but french fries are one of my guilty pleasures.
RioWilson
Images: 21
Postby Dale M. » Mon Oct 28, 2013 8:21 am
For me It would depend on drive-thru... Some have a pretty tight turn in them so they could make them fit property..... IF bend are short/tight, NO... If its a straight shot, maybe...
Dale
Dale M.
Images: 18
Postby TPMcGinty » Mon Oct 28, 2013 11:31 am
Done it many times. Never had a problem.
Tim
TPMcGinty
Images: 146
Postby rowerwet » Mon Oct 28, 2013 12:04 pm
we've always found a place to park, even in a parkng lot across the street.
the tear tows just fine though drive thru's, bank drive ups and gas stations though.
rowerwet
Images: 521
Postby grant whipp » Mon Oct 28, 2013 9:17 pm
I do it all the time, rarely do I ever have to think about it. About the only time I worry is when I'm pulling the canned ham, and then all I worry about is the overhead clearance. Just another advantage of tiny trailering ... ;) ...!
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby Verna » Mon Oct 28, 2013 9:22 pm
I just did it tonight. I swung wide and the tires didn't 't even come close to the curbs. And, I had already driven over 7 hrs and still had 3 more to get home. I didn't 't want to cook..I wanted to get home!!
Verna
Indianapolis, IN
Verna
Images: 49
Postby Roly Nelson » Mon Oct 28, 2013 9:29 pm
Some of you might know that I have a Jack-in-the-box head hanging in the window of my woody. Once when I drove through a Jack-in-the-box joint, I told the gal at the window that I had her boss in my trailer back there. "Oh, sure you do" she said and I told her to just watch and see as I drove forward for her inspection..........Hmmm, no response, what a waste of effort. However, as I rounded the exit lane, 5 Jack-in-the-box employees rushed out the front door, to take a look at what the gal at the window had seen and told them. Just had to share that bit of whimsey.
:? 8) :thumbsup: :applause: Roly :FNP
Roly Nelson
