Larry C wrote:Hi Whitney,
I applaud your desire for light weight. I too have similar desires. I don't know your ultimate weight goal, but mine is 5-600# total loaded trailer. I think this is doable and should not tax even a small car.
Here's my build journal if your interested:
http://www.tnttt.com/viewtopic.php?t=35852&postdays=0&postorder=asc&start=0
Nice!! Like the stripper in the background, too - Guillemot? My next project is a trio of S&G Night Herons...
I am wondering if your choice of materials will actually be as light as a lightly framed wood/foam core with 1/8" plywood skins. Your choice of 15oz. roving will require a lot of heavy epoxy to fill and fair. Also, my experience with honeycomb foam is it soaks a lot of epoxy, adding even more weight.
The Plascore I'll be using is a polypropylene hollow-cell with a film and veil on both sides so it can be vacuum-bagged without cells filling. Weight is 4-5 lbs. per cubic foot. As for fairing, I may or may not - my goals for this are a bit different than a lot of folks here, as I'm looking far more for functional than for attractive.
If I were you, I would assemble a small test panel of your proposed materials and alternate methods, then weigh each to see if the time /expense is justified.
Definitely planning on it, but you'd be amazed at how cheap this stuff really is. Panel weight is quite low, too.
One of the things I'll be testing is impact strength of various panel thicknesses with 6oz., 10oz., and 15oz. cloth/roving. All the talk of 1-1/2" floor and 1/2" body being "too thick" got me thinking, so I'll be testing 1/4" and 3/8" body panels as well.
My "heavy" limit for this trailer is ca. 1000 lbs. fully loaded weight, carrying an Abex 10x10 tradeshow booth weighing approximately 550 lbs. This leaves about 450 lbs. to make a trailer out of, but it needs to be fairly impact resistant on the inside. The "hauler" requirement is what's making the trailer so big - I want space aft of the doors for the booth and between/forward of the doors for me to nap in at rest areas. The booth takes up approx. 4'x5'x3' plus misc bags o' stuff.
There's been some concern voiced about cabinets, etc. - all I can say is that between cored panels with thin skins and foamed PVC sheet I think I can keep the full cabinet set down to under 50 lbs.
A further concern of mine is maintenance-free longevity - a nice white epoxy paint over a totally composite body and interior should mostly eliminate decay and the need for frequent maintenance. This is of major concern here in the tropics...
