by alffink » Thu Jun 16, 2011 12:12 pm
Hi all, one quick lesson on putting up and taking down an EZ-Up
(I have used EZ-Ups for over 25 years) Only TWO people needed even for the larger shades
going up,
do not extend (raise) the legs,
open up about arms width
with two people - look at the acordian bars, there will be a set of V's in the middle one pointing up and one set pointing down
When putting UP grab the lower V pointing DOWN, one hand each side
the second person does the same on the opposite side
Now, each person lightly lift, and walk away from each other and all four legs will spread evenly
When coming down, either push the locking button or pull the pins First
then grab the V pointing UP, lift lightly, and walk towards each other, be careful not to get pinched when everything comes together.
Think you will find this a whole lot easier than having some one on each leg.
With a bit of practice, one person can do this, working it out in stages from opposite sides. Some find staking one leg will assist in one person set-up, I do not find this method any easier, but you may want to try it.
Remember do not force it, if something isn't moving when coming down, there is probably a leg that is not un-pined
