Battery location
Postby absolutsnwbrdr » Fri Jan 13, 2012 2:05 pm
This is what I'm planning on doing.
All bolt-together, from 14 gauge 1-1/2" steel angle The orange in the screenshot is 1x2 boards used to reinforce the 1/2" plywood trailer deck around the opening.
All the steel angle will be bolted together with 3/8" bolts, and the assembly will be attached using carriage bolts through the trailer deck and 1x2 boards.
Might not be pretty, but should be plenty sturdy, even for my driving.
And I can always come back and box it in with some thin plywood.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Woodbutcher » Fri Jan 13, 2012 8:01 pm
That could work Zack!
Woodbutcher
Postby absolutsnwbrdr » Fri Jan 13, 2012 11:26 pm
Worked on it tonight. :D
Used 16GA angle...
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Kharn » Sat Jan 14, 2012 7:26 am
Zach,
I'd definitely box it in to keep the battery free of road grime and cut down on rodent/insect infiltration.
Kharn
Postby Woodbutcher » Sat Jan 14, 2012 9:45 am
Yea that's what I was thinking to. This looks like a perfect solution for me. Thanks Zack for the idea!
Woodbutcher
Postby Sonoma ZR2 » Sat Jan 14, 2012 11:40 am
I can tell you that at Winnebago the coach battery compartments are closed to the sides but open to the bottom just a couple straps running underneath. Then some threaded rod and a strap bolting them in. They are sealed only from the interior of the rv but open on the bottom for venting.
Sonoma ZR2
Images: 90
Postby absolutsnwbrdr » Tue Jan 17, 2012 2:30 pm
Its going to have a cover on top, and I think I'll put a piece of plywood on the front face of the box to protect from flying road debris, but I probably won't box the whole thing in.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Users browsing this forum: Google [Bot], jgmahoney, tony.latham, Westy and 10 guests
