I think it's time to revisit the weekender.
Re: I think it's time to revisit the weekender.
Postby GPW » Sun Mar 18, 2012 7:47 am
Mike , so SAD to see the Big TD hacked up like that !!! :cry: The New Weekender looks very “airfoil" shaped ... pretty Cool!!! 8) ...Great use of standard size wood ... or Foam ... :o
Postby mikeschn » Sun Mar 18, 2012 8:07 am
Glenn,
With my renewed fear of water, I decided to put the hinge for the hatch at the highest point possible. Then to further minimize the chance for water to get in, I made the hatch almost vertical.
Suddenly it's looking more like the rockhopper design I did a number of years ago... So I may have to change the name from Weekender to something else...
But for the moment, it's still the Weekender II
Postby Dan & Julie CO » Sun Mar 18, 2012 8:15 am
Has the thought of making with it with a slope and rear entry w/ side slide out kitchen toward the front ?
Dan & Julie CO
Images: 56
Postby mikeschn » Sun Mar 18, 2012 8:23 am
I dug out a few old pictures...
Postby mikeschn » Sun Mar 18, 2012 8:47 am
Dan & Julie CO wrote:Has the thought of making with it with a slope and rear entry w/ side slide out kitchen toward the front ?
You mean like the RT? No, I never gave it much thought.
Postby Dan & Julie CO » Sun Mar 18, 2012 9:23 am
a little more blunt like the green lantern in shape. with a draw slide out kitchen,wouldn't there be a quicker build turn around ? I don't know just random thoughts.
Dan & Julie CO
Images: 56
Postby Dan & Julie CO » Sun Mar 18, 2012 9:32 am
My bad I'm trying to veer off to far from original design. I was thinking in terms of less seams quicker turnaround. I'll talk to myself in my head LOL :?
Dan & Julie CO
Images: 56
Postby mikeschn » Sun Mar 18, 2012 4:28 pm
I mocked up a side wall of the Rockhopper II for Chell today...
Here it is...
She says it's too small. :cry:
Postby Martiangod » Sun Mar 18, 2012 4:32 pm
Are you going for a standy, slouchy or a true rolling mattress...AKA Tear?
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby mikeschn » Sun Mar 18, 2012 4:55 pm
Chris,
Well, I thought I was going for a mad dash across the country teardrop... what ever that means...
Actually that means no porta potty in the teardrop...
So a mattress on the floor, wheels outboard, and a galley out back.
Postby mikeschn » Sun Mar 18, 2012 4:58 pm
So she says, It needs to be 11 inches taller. :duh:
So I find a piece of wood 7 inches taller and make the modification.
She says she likes it... :phew:
Postby Martiangod » Sun Mar 18, 2012 5:07 pm
Whats the floor length on the old trailer, 10' ?
Chris
Martiangod
Images: 432
Postby mikeschn » Sun Mar 18, 2012 5:16 pm
Martiangod wrote:Whats the floor length on the old trailer, 10' ?
The old trailer is 10', but I am going to chop 2' off.
Postby Larry C » Sun Mar 18, 2012 5:50 pm
Mike,
Sounds like your getting close to your "Ultralight" design....
Larry
Larry C
Images: 78
Postby Martiangod » Sun Mar 18, 2012 5:51 pm
If you go for 8 feet of roof, run your ply front to back, then your length wise cut off will work cross ways front or back.
The mini truck camper kick off the back, I did mine that way, sheds water off the roof away from back wall, do a full wall lift, inside the walls, real easy to weatherstrip on all four sides
If you go 10' overall, 10' aluminum is readily available, And I strongly suggest aluminum or membrane roof, properly sealed will last a long time
Couple real quick sloppy chops
Chris
Martiangod
Images: 432
