the beaty of the furom diffrent opions.
Re: the beaty of the furom diffrent opions.
Postby Gage » Wed Nov 28, 2012 11:10 pm
Vedette wrote:Guess not!
I guess I need computer lessons?????????
Brianr
In your album, click on any thumbnail for the larger version. Then when it comes up copy the Image-URL and then when you post it, it'll show like this:
P.S. You can see how I did it by clicking on the Quote button to the right and then review the way I typed it. Be sure to take notes. ;)
Image Image Image
Gage
Images: 28
Postby eaglesdare » Thu Nov 29, 2012 7:44 am
i just tried to do your way (gage), but when i click on the image, my computer asks if i want to save it. that is my only choice. those img codes do not show up for me. that is why i use photobucket, from there i can get those codes.
Louella
May the foam be with you.
eaglesdare
Postby GPW » Thu Nov 29, 2012 8:36 am
Eagle , you need to use your personal album more ( I’ve somewhat over-used mine :oops: ) ... it’s all there ... Easy to use , once you get used to it. 8)
Postby eaglesdare » Thu Nov 29, 2012 9:20 am
i would use it, but my system will not show those img codes that make it larger. only small images. i can figure out how to do something if my system does it. its not a big deal. i've been doing this for a while now. for me, i will post pic with photobucket, and to view the smaller images, i just go to their album. i can do a work around. :D
Louella
eaglesdare
Postby Gage » Thu Nov 29, 2012 12:31 pm
Image From your album Louella. :)
:thinking:
I have windows 7 and I believe IE 9.
Image Image Image
Gage
Images: 28
Postby eaglesdare » Thu Nov 29, 2012 12:35 pm
see i can't do that! its irking me. :lol:
Louella
eaglesdare
Postby eaglesdare » Thu Nov 29, 2012 12:45 pm
i have windows 7. i just did a check and i am running ie9 also.
i can go into the album and click once on an image. if i click on it again, i get a pop up that asks me if i want to save.
the only choice i have is a code for the link and then the other code for the small image to show up. i think the problem is that i can't click the pic a second time (that is when the save pop up happens). and i think the second click is where the img code for larger pic is.
Louella
eaglesdare
Postby Gage » Thu Nov 29, 2012 1:03 pm
Just click on the thumbnail once with the left button on your mouse and that should get you the larger picture with the coding noted below it. :worship:
P.S. With this posting, I'm using Foxfire.
Image Image Image
Gage
Images: 28
Postby eaglesdare » Thu Nov 29, 2012 2:30 pm
nope doesn't work. get the pop up for "save". oh well, like i said no big deal. gotta move on now. :)
Louella
eaglesdare
Postby Vedette » Thu Nov 29, 2012 3:53 pm
99871
Okay Gage
I was getting that same "Save" message as Eagle.
But I thought I would give it another try.
Clicked on the thumbnail and it enlarged. Scrolled down and saw the 99871 code.
Highlighted it, right clicked selected "copy" closed that window returning me to this post. Right clicked selected "paste"
and here is what I got.
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Vedette » Thu Nov 29, 2012 3:55 pm
Okay obviously where ever I type in the code that I brouhgt over from my ALbum just pops up the picture.
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby eaglesdare » Thu Nov 29, 2012 4:28 pm
see its the small size.
can you click your image, and then click your image again?
Louella
eaglesdare
Postby eaglesdare » Thu Nov 29, 2012 5:50 pm
biziedizie wrote:Go to your gallery, click your pic to expand it, copy the url, click out of your pic, go to your post, click img and paste your url in between the parenthesis.
It works great but it makes the pic too big, you can resize your pic but it seems much easier to just insert the img and if people want to see it bigger they can click it to expand it.
i tried that also. nothing happened just the words and codes.
Louella
eaglesdare
Postby Gage » Sun Dec 02, 2012 9:42 pm
You guys are clicking on the wrong code and I'm not going to say any more because Kevin will give me strike 3.
Aw, hell with what admin thinks. Louella, add the image tags to the below coding and see what happens. Then go into your gallery and see if you can find the coding I used.
:thinking:
http://www.tnttt.com/gallery/image.php?album_id=2756&image_id=99724
Image Image Image
Gage
Images: 28
Postby Vedette » Mon Dec 03, 2012 1:48 am
Why would the administrators give you strike 3 for helping others here on the Forum?
Thanks for all the help you have given me!
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
