impractical designs
Re: impractical designs
Postby Vedette » Fri Feb 01, 2013 3:53 am
Looking at the last sketch on graph paper, I figure your bed will be 74"?
I think 78" 's the optimum lenght for a comforable teardrop.
Thus, I would make it 100" rather than 96" ( buy 10' sheets of plywood for the sides)
And use 0.125 wall 2or 0.188 wall 2"x3" tubeing for the chassis. (0.250 wall is overkill)
Just my 2 cents worth.
Very cool design!
I llove the doors and hinges.
Good Roads
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby Bogo » Fri Feb 01, 2013 9:42 pm
I was trying to stay within the sizes of common plywood sheets, 4' x 8' and 5' x 5'. It was an exploration. In the long run I figure FRP/foam/FRP SIP panels is the way to go for construction. I can get thin FRP sheets that are 100" x 40' x 0.055" Hum.. .. ..
Anyways, I'm again thinking mostly about larger hard sided pop-up designs, and sculptures. :twisted:
Bogo
Images: 39
Postby Heifer Boy » Sat Feb 02, 2013 8:51 pm
I like it :)
How about making it a clam-shell to get your head height? You could hinge it front or rear because you have done away with the kitchen. Do you think you may need a more substantial chassis if you are going to put 31's on it? You would have a lot of trail capability and I would hate to be tempted to go beyond it's abilities.
BTW I think that same way about a kitvhen. A lot of people forget that they have a tow vehicle with a lot space already available. It also means you can set camp and go exploring and still your food, fridge and cooking stuff with you.
Heifer Boy
