fishing and teardropping.
Re: fishing and teardropping.
Postby Rainier70 » Wed Feb 06, 2013 6:30 pm
Fishing is the reason!
Rainier70
Images: 244
Postby Mary C » Sat Feb 09, 2013 12:54 pm
camping while fishing or fishing while camping. The reason I wanted to build and camp in a tear drop is because setting up and taking down camp takes too much of my fishing time. I have thought about the problem of traveling with fishing poles and thought about breaking down and taking off the reel and that is again so time consuming so .......since I sew and have gotten an idea for a simi hard cover. My fly pole doesn't break down so I have to have a long keeper. I also have been thinking about making some type of a foam cover. I just have to keep the art of kiss in mind.
Mary c. :)
Mary C
Images: 473
Postby Miriam C. » Sat Feb 09, 2013 8:57 pm
I throw the poles in whatever I am driving. I have discovered I can put the poles above the curtain rod too. Working on a top for the tear and a rack or cover for the truck. The kayaks go in the truck for now.
Postby droid_ca » Sun Feb 10, 2013 12:30 am
I have a few of the collapsible rod set ups always in my vehicles...you never know when you'll find a new spot you want to try 8)
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby S. Heisley » Sun Feb 10, 2013 4:01 pm
Miriam C. wrote:I throw the poles in whatever I am driving. I have discovered I can put the poles above the curtain rod too. Working on a top for the tear and a rack or cover for the truck. The kayaks go in the truck for now.
Hey, Miriam! Your new set-up looks great! That red stripe on the trailer points right to the red truck and ties it all together nicely.
...Now, back to your fishing subject.....
Postby Miriam C. » Wed Feb 13, 2013 8:30 pm
Mary C wrote:,......I also have been thinking about making some type of a foam cover. I just have to keep the art of kiss in mind.
Mary c. :)
:thinking: Ahha....I wonder if one of those pool noodles will work? ;)
Postby Mary C » Wed Feb 13, 2013 9:39 pm
It might work for one but since I want to make it sorta hard too. I want to put three rods in it.sooooooo......I don't know but I will think on it. I was sorta thinking bout going with one about 8 inches and use the extruded foam to sorta dig out and make a hard case covering it on the outside with canvas. thanks for the suggestion!!
Mary C. :)
Mary C
Images: 473
Postby Jerry & Molly » Thu Feb 14, 2013 12:02 am
Don't have my teardrop done yet. :x But do plan on doing alot of fishing when we're camping. I already have a rod case for the rods that I bring with. My problem that I have is because Molly and me use float tubes for fishing is, Where in the heck do you put a couple of wet float tube. :thinking:
Jerry & Molly
Postby Rainier70 » Thu Feb 14, 2013 5:11 pm
I put my floattube in a rubbermaid tub. Then soon as I can I get it back out and let it dry completely.
A pool noodle works well for a small rod. I have used one for about 5 years on a rod I hike with. I slit the noodle all of the way up one side. Then I rubberband the rod together or leave it strung up. Light pressure will open the tube slit and I can slide the rod in.
Home Depot has plastic protective tubes for florescent lights that work also. http://www.homedepot.com/h_d1/N-5yc1v/R ... R1gxmddCSo
Rainier70
Images: 244
