Spare Tire?
Re: Spare Tire?
Postby DMcCam » Sun Jun 29, 2014 7:40 pm
citylights wrote:How much clearance do you have between the ground and spare? If you have a flat, I hope the spare won't drag and will you be able to get under to detach the spare?
Hi John, It is pretty low with about 8-9" of clearance. As long as I don't loose the rim on the flat tire everything clears. I drive slow anyway. She is not an off road trailer for sure. One thing though, if you have the space behind the axle, it does help to keep you tongue weight down a bit. I also like the adapter to use your TV's spare...pretty cool.
Best,
Dave
DMcCam
Re: Spare Tire?
Postby pohukai » Sun Jun 29, 2014 8:43 pm
pohukai
Images: 9
Re: Spare Tire?
Postby printer88 » Sun Jun 29, 2014 9:51 pm
pohukai wrote:Image
Dude? I could have lived without seeing that. lol
"When all is said and done....a lot more will be said than done."
printer88
Re: Spare Tire?
Postby cheri832 » Mon Jun 30, 2014 6:31 pm
I'd say that one is mounted in front of the axle....... :shock:
Cheri
cheri832
Images: 15
Re: Spare Tire?
Postby Micro469 » Mon Jun 30, 2014 8:29 pm
cheri832 wrote:I'd say that one is mounted in front of the axle....... :shock:
Or above.........
John
Micro469
Images: 382
Re: Spare Tire?
Postby doris s. » Mon Jun 30, 2014 8:49 pm
Well, since I was dumb and didn't plan for a place on the teardrop when building. I'm going buy a spare mount to place in the back of my truck. At least the tire won't be rolling around in the truck bed. I have tried to figure out where it would go on the big woody but there really is no safe place. Ugh. The next build I'll be sure to plan for the spare tire. I really don't want to have the teardrop unbalanced driving on the highway. Thanks for all the good safety advice.
Doris
doris s.
Images: 32
Re: Spare Tire?
Postby LeeOrlando2 » Mon Jun 30, 2014 9:03 pm
Mary C wrote:When I get rich I plan to go to the junk yard to get the mechanism off an old GM truck. In the mean time I will just use Long bolts to the frame.
Mary C.
I once had a 1998'ish Nissan pick up that had the crank down mechanism so that give you another model to maybe find as junked. Sounds like a good idea too!
LeeOrlando2
