Solar panels
Re: Solar panels
Postby Esteban » Sun Jan 31, 2016 10:13 pm
If your total budget for a solar power kit is $250.00 you might need to step down to a 100 watt panel.
Amazon.com sells a 100 watt Renogy panel, a mppt controller and panel mounts for $222.46
I personally favor using a mppt charge controller which harvests more power (up to 30% more) from a solar panel than a less costly pwm charge controller. You wrote that you want a fridge. So getting all the power you possibly can from your solar panel is important.
A needed first step is to estimate your daily power needs. Then design a system to meet, or exceed, that.
Steve - SLO, CA
Esteban
Images: 15
Re: Solar panels
Postby Pinecone » Mon Feb 01, 2016 4:31 am
I got my panel from http://www.powerenz.com. Best feature is portability...and space is always at a premium for small travel trailers.
G. Pang, NW Tear Jerker
Check out Teardrop Event Videos I put together!
IRG 6.0 2016: https://www.youtube.com/results?search_query=IRG+6.0
TOW Promo 2017: https://www.youtube.com/watch?v=mpxgE7H3CrA&t=11s
Pinecone
Images: 28
Re: Solar panels
Postby booyah » Mon Feb 01, 2016 1:53 pm
If you are running two 35ah batteries in parallel for a total of 70ah @12v you'd be well suited by anything in the 70+w range.
100w would give you a nice safety margin, anything larger really is overkill
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
